Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
abscate wrote: 20 Jun 2022, 18:39
Goupil wrote: 20 Jun 2022, 11:22
Sveedy wrote: 19 Jun 2022, 19:29 Very cool on getting things back installed. Great feeling, I know.
And your right - somewhere around 4:00 am the answer will probably come to you.
4:00am didnt help, but walking around the garage did :lol:
The car pops and run like shit for a second then stalls again. I replaced the cam seal behind the distributor, and looking at the rotor plate from the other engine it seems possible to install it 180° off :? that wouldn't help :mrgreen:
Weather isnt on my side, it was 90°F on saturday and 54° and rainy on sunday !
You have to be a real monkey mechanic to do that
viewtopic.php?t=94920&hilit=1998+start
Thanks for that link, missed it when searching for some pictures.
I was able to confirm the distributor rotor was in the right place. That means I did that part correctly even if I remember it, but that doesnt solve my no start issue :mrgreen:
Trying not to be that annoying neighbour that cranks the starter for hours in the evening, so havent done much more troubleshooting.
Decided to go cut up some volvo parts in the garage instead :lol:
(3" downpipe was touching that brace and making quite the rattle !)
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Had a hot ride today when the AC decided to cutout. VolFCR indicated a bad AC pressure sensor. Live readings showed intermittent -162KPA indicating a bad reading. Dielectric greased the high pressure sensor at first and then realized it was the low pressure sensor by the passenger headlight. Looked like wiggling the connection caused a bad reading. Cleaned terminals and applied a liberal amount of di-electric grease. Now my AC is back to a chilly normal which is needed in 32+ celsius weather.
2008 S60 2.5T Auto (Sold)
Has thanked: 1504 times
Been thanked: 3817 times
Caitlin came over after work and we dropped in a fresh alternator, serp belt T60 , cabin filter, turn light, into Shagg. I made the same mistake I did in the Kat , s70 and forgot to tighten the lower AC bolts. I’ll tighten them Tomorrow am before she leaves,,,,at 0630
:lol:
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
abscate wrote: 22 Jun 2022, 20:51 Caitlin came over after work and we dropped in a fresh alternator, serp belt T60 , cabin filter, turn light, into Shagg. I made the same mistake I did in the Kat , s70 and forgot to tighten the lower AC bolts. I’ll tighten them Tomorrow am before she leaves,,,,at 0630
:lol:
Good thing you're already up before then; and you just saved me from putting a spare turn signal in the box headed North in the big Dark Burgundy container.
Swapped out the car / right engine/ front motor mount with the new one, partv666 with the easily adjustable mount design…
Kat approved inspection, took Husky for a walk, replaced a lower rad hose clap, ugly
Buzz!
MrAl
Year and Model: v70, 1998
Been thanked: 73 times
Post by MrAl »
Ran over a werewolf and killed it. My car is silver it's the only kind that will kill a werewolf, any other car he would just get up and walk away. Has to be silver.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
^ I read that's the reason that they are on the Endangered Species List. Just too many of us silver cars.
1999 V70 GLT
MrAl wrote: 24 Jun 2022, 07:59 Ran over a werewolf and killed it. My car is silver it's the only kind that will kill a werewolf, any other car he would just get up and walk away. Has to be silver.
426 is the number that kills the Beast...
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
I miss my Grayson…..🥲
That’s a big one…..
