I'm at my wits end.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Earl
Year and Model:
Post by Earl »
Thank you Bill . You say The Green/red is the other side of the switch in the relay and should go hot when the ignition is switched on. The blue/yellow should also go hot when the ignition is switched on but it gets its power from the fuel pump relay.
I have no juice at all from either of those two wires .
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I should have also added that the green/red would go hot if the relay worked.
The red wire is hot at all times but the relay stops the current flowing to the injectors (via the green/red wire) until the relay is activated. This activation is via the blue/yellow wire from the fuel pump relay. The theory is that when the ignition is switched on the blue/yellow wire goes hot, activates the switch inside the radio suppression relay thereby allowing current to flow to the injectors.
If you have no power through the blue/yellow wire the relay will not activate. Locate the fuel pump relay and check the blue/yellow wires at that point with the ignition off and on. You should find 4 blue/yellow wires going into, and out of, two terminals.
If you haven't already done so check fuses 1 and 11.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Earl
Year and Model:
Post by Earl »
Sorry for the long delay, health problems had me down a bit .
I checked the wires and finally found the problem.
For some odd reason both fuel pumps were working , even had fuel all the way up to the injectors as I had stated...but the nearest volvo dealership told me that the fuel pump relay operates the injectors as well and felt that this had to be the problem . So I replaced it and she fired right up . :o
Sure is sweet having the old car back up to par . :D
Thanks for all the advice Bill and everyone else.
billofdurham
Thank you for the update. It's a good feeling when you get it sorted.
Hope your health problems have gone the way of your car problems.
Bill.
Previously:
