Missing Vacuum cap? PO171, high fuel trim, ckg vac hoses
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
CarCapers
Year and Model: 2008 S40
Post by CarCapers »
2008 non-turbo 2.4 s40, P0171 code triggered while at idle, just 3 minutes after starting and had fuel trim of 23%
When looking for damaged, cracked, missing vacuum lines I noticed this incongruously clean and shiny stub north of the oil filter (see photos) when facing the engine, looking at the passenger side front quarter, looking down and slightly at an angle. Specifically, if the oil filter cap is center of clock, this horizontal stub is at 11, and pointing to front of car.
Really looks like something used to be covering the metal stub because it doesn't have the same dark patina of oily dust as all around it. Could this stub be connected to the vacuum network? Should there be a cap or tube on the end of this stub? I have spent time going through the Haynes book but not sure what system this stub is contiguous with so it's a needle in a haystack sort of investigation.
passenger side front of engine.jpeg (48.32 KiB) Viewed 611 times
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 36 times
Post by theWIFES_S70 »
I drive a 2007 non-turbo S40 and that hole is similarly clean. Your vacuum leak is coming from somewhere else. Maybe the hard lines that snake over the right side of the engine? Good luck tracking it down, it sounds like a pain...
Retired:
2015 Volvo S60, T5, 85K
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Buy a cheap smoke machine
BMW 540i 2002
S70 Base 2000
