Vida CEM swapping
RickHaleParker
Been thanked: 958 times
Re: Vida CEM swapping
Post by RickHaleParker »
T5Luke wrote: 21 Jul 2022, 16:24 I can also post bootloader to dump cem, maybe it has use for teensy project...
Could dump to the terminal . Copy and paste to a binary file. Process could be reversed for flashing.
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
Here this is minimum connection to CEM on bench.
On D connector:
Green: HS CAN-L to pin 14 OBD
White: HS CAN-H to pin 6 OBD
Grey (pin 6 ): GND
Yellow (pin 8 ): +12V
Blue (pin 15 ): +12V
Also it needs +12V on the both big connectors (big green power socket)
bosse
Year and Model: V50 -11
Post by bosse »
Pin 8 and 15 is not needed.
T5Luke
Post by T5Luke »
If you don't want to fall the cem asleep and run it in a diagnostic session you need power on pin 8 and 15.
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
folks , I want to buy a teensy , i found afew suppliers , is it the 4.1 dev board or the teency LC dev board with bootloader? im gonna take the plunge and bloody well get one. buuut which is best for this application ?
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
Teensy 4.0.
oscilloscope
vtl wrote: 01 Aug 2022, 14:19Teensy 4.0.
ugh the only one not in stock my luck
vtl
Post by vtl »
oscilloscope wrote: 01 Aug 2022, 14:21
4.1 may work as well, it is based on the same chip.
oscilloscope
vtl wrote: 01 Aug 2022, 14:26
ah i'll just get the 4.1 if it doesn't work at least i have a thing to aid me in the journey into programming something. or i could nail it to the wall
T5Luke
Post by T5Luke »
I have both and on both of them the same code works. So have fun with it...
