Bad bearing noise and vibration under drivers feet at 30mph and up
forestfarm
Year and Model: 2004 xc 70
Post by forestfarm »
I’m certain the axle is fully seated. Same vibration with new axle and bearing. I will replace the right side parts arrive Wednesday
forestfarm
Glad to report that the vibration is finally resolved,it was the right side wheel hub or the right axle,Both parts seemed to be fine turning them by hand,all the vibration was felt on the drivers side under floor.Very humbling to have mis diagnosed problem and starting working on the opposite side.All is happy now,will have to service the rear diff and haldex unit now that the front is freshened up.The parts cannon is completely out of ammo
forestfarm
Both axles and wheel hubs replaced,new angle gear coupling and transfer case,good used unit off of lower mileage vehicle.Mne was still functional but the splines were almost trashed after 196K miles
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
forestfarm wrote: 27 Jul 2022, 09:50The parts cannon is completely out of ammo
I have this problem as well!
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Glad to hear that your car is happy again! You can chalk it up to most of those parts you replaced are probably near their end of service anyway, and you fixed the angle gear before it failed and before winter.
2003 XC 70 (sold)
SteveV70
Year and Model: 2007 V70
Been thanked: 3 times
Post by SteveV70 »
Thank you for following up and letting us know what the result was. Too many times the original poster just disappears when they find the issue. It’s when folks follow up and post successes is when the collective knowledge grows. Eventually someone will find this thread on a search and be REALLY happy you did.
Good on ya.
And you got your beastie back on the road to boot.
Nice.
