Did combat with the torque rod bushing, 9434263. After intense negotiations, and finishing with the Large Hammer, it yielded.
And the warning Robert sent out some time ago still holds true; the Meyle bushing is too small, and rattles around in the bracket.
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
- Has thanked: 1846 times
- Been thanked: 1710 times
Did you rotate it 10 degrees forward as recommended by Volvo!??
- Ocelot
- Year and Model: 1998, S70
- Has thanked: 61 times
- Been thanked: 17 times
So yesterday, in the blistering heat, I changed the timing belt, waterpump, tensioner and "looprol" (don't know what that part is called in English). Everything went smooth, cars runs like a charm. There's this thing however, that bothers me. What is the actual interval? I've got a Haynes manual suggesting 120.000 kilometers or 8 years. I've got a Volvo dealer that suggests 165.000 kilometers or 10 years. And when I searched MVS, I even came across someone mentioning 75.000 kilometers or 5 years. Okay...
My S70 has a 2.5 liter, 10 valve engine from august 1998. Enginecode B5252S. If someone would shed some light on this, I'd be very greatfull!
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Recent car
- foggydogg
I have always thought 70,000 miles was prudent for our 20 valve motors ( around 115,000 km ? ), but I don't have an owners manual with me at the moment. Given the relatively small price for the parts, and the large price for a disaster, it probably isn't worth the wager on going more than ten years. The Volvo dealer is presuming Volvo Blue Box parts are used; your 10 valve non-turbo motor may be a bit gentler on the valve train.Ocelot wrote: ↑15 Aug 2022, 01:20 So yesterday, in the blistering heat, I changed the timing belt, waterpump, tensioner and "looprol" (don't know what that part is called in English). Everything went smooth, cars runs like a charm. There's this thing however, that bothers me. What is the actual interval? I've got a Haynes manual suggesting 120.000 kilometers or 8 years. I've got a Volvo dealer that suggests 165.000 kilometers or 10 years. And when I searched MVS, I even came across someone mentioning 75.000 kilometers or 5 years. Okay...
Stay hydrated in the Tropical weather that has descended over you now, fall is coming.
- Has thanked: 304 times
- Been thanked: 517 times
75,000 KM seems too soon, 75,000 miles is a little more realistic. That was the initial recommendation on earlier cars, however the later cars (1999-2000) recommend either 100k or 120k miles (160k KM) or 10 years.Ocelot wrote: ↑15 Aug 2022, 01:20 So yesterday, in the blistering heat, I changed the timing belt, waterpump, tensioner and "looprol" (don't know what that part is called in English). Everything went smooth, cars runs like a charm. There's this thing however, that bothers me. What is the actual interval? I've got a Haynes manual suggesting 120.000 kilometers or 8 years. I've got a Volvo dealer that suggests 165.000 kilometers or 10 years. And when I searched MVS, I even came across someone mentioning 75.000 kilometers or 5 years. Okay...
- Has thanked: 1503 times
- Been thanked: 3817 times
Time to look in the Service interval section in the manual. We don’t get the 10 valve car in the lower 50 provinces, the change from 75,000 miles to 105,000 miles intervals happened in mid 1998 with the change from hydraulic to mechanical tensioner
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 129 times
Ah, so that's the difference. I have not had the mechanical part in hand, but from pictures/video describing how to adjust it, I've been glad not to have it. The hydraulic seems to work fine to me. In fact, the original I removed from my car seems to be in decent shape still.
I assume you've had both abscate, do you have a preference?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
The hydraulic tensioner seems to last longer too, which is why I find it interesting that Volvo extended the service interval with the mechanical tensioner. The pulley itself should be changed every timing belt service, but the hydraulic ram tends to go forever unless it's leaking.
I prefer... the one that fits on the car. Its not a choice we make, the block is machined with holes for one or the other, at a chassis break.454cid wrote: ↑16 Aug 2022, 07:31Ah, so that's the difference. I have not had the mechanical part in hand, but from pictures/video describing how to adjust it, I've been glad not to have it. The hydraulic seems to work fine to me. In fact, the original I removed from my car seems to be in decent shape still.
It might be the temperature compensation on the mechanical allows a better set on the tension leading to the longer service life - or it might just be that the data supported a longer life. I would guess the latter. I ran my own experiment running my RN to 140k/ 14 years on its original belt, idler, pulley, and tensioner.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
I'd rather have the hydraulic tensioner, purely because it takes 0 thinking to install
the mechanical one is a bit fidly
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
