- Has thanked: 1498 times
- Been thanked: 3810 times
Took the morning and in two hours got the head bolts cracked. Still have to go under for exhaust disconnect but pretty close to having head off for fixing bent valves
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Careful, you're getting to be like me; a yard full of cars, but running out of stuff to drive.
Meanwhile, back on the Difficult Redheaded Child, The warnings about the Continental belt are also still true, just a wee bit too short for my taste. I'm not a fan of forcing a belt over a pulley; our friend Robert has mentioned it several times, as has Dr. Abscate.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Time for first oil change after drain tap installation. I must say it went pretty well. I was planning on attaching a hose/tube to the tap and lead it right to my oil recycle tank but I couldn’t find any at home. Oil maybe evacuates a little slower with the tap but it’s nothing you think about really.
- 61D73D0B-21D7-44EA-B039-17B7911C3593.jpeg (838.39 KiB) Viewed 645 times
- C98EDA20-C55F-424E-8149-5F206E8803F1.jpeg (341.84 KiB) Viewed 645 times
- 7E7AB735-3E98-4AD1-809D-B11202A780A4.jpeg (540.18 KiB) Viewed 645 times
- FCB4F107-6BF3-4A32-AF2E-6EFC6153191C.jpeg (475.83 KiB) Viewed 645 times
BMW 540i 2002
S70 Base 2000
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Can you rig a switch to this so it makes a James Bond oil slick behind you?
(Not approved by the EPA or any responsible citizen)
This is actually a really handy gadget - thanks for the pics.
- MrAl
- Year and Model: v70, 1998
- Been thanked: 73 times
Hello there,kallekula wrote: ↑18 Aug 2022, 12:55Time for first oil change after drain tap installation. I must say it went pretty well. I was planning on attaching a hose/tube to the tap and lead it right to my oil recycle tank but I couldn’t find any at home. Oil maybe evacuates a little slower with the tap but it’s nothing you think about really.
Hopefully it does not open by accident on the road.
Safer than the monkeys at Quicklube who will either gorilla your oil plug or finger tight it.
The EPA and CIA are in deep conflict over this one
Pumped 10 gallons out the Kat prepping for fuel pump change, stuck brand new key from Volvo into door and broke tumbler
Crap on rye
Crap on rye
