Mangefine Filter Installed w/ Pictures
This topic is in the MVS Volvo Repair Database » Mangefine Filter Installation Tutorial w/ Pictures
CNGBifuel
Year and Model: V70 1999
Re: Mangefine Filter Installed w/ Pictures
Post by CNGBifuel »
I confirm on my 1999MY V70 I used a Magnefine in reverse to that shown. Thus flow coming from the transmission >>> to the top hose on the rad. Because I was cutting this hose anyway I did not touch my Green clip. Left it as it was. I used a 3/8" Magnefine, (not avialble in teh UK), but got it from you lot across the pond. I believe Wix do a similar item.
On a 1999 Volvo I found I had to put an elbow into teh hose to be sure of not kinking it. I used the Toyota spec oil. I have the AW5 (5 speed box). i think 850s can use Dextron. MY1999 5 speed cannot. I have an 'L' on my box indicator, thus L34RDP.
I also broke my dipstick, old and brittle when cold, but it will not fall into teh box. There is a stop-end on my box so after removing the dip-stick tube it came out easily. Had I known about the stop-end I'd have left it there! I used the broken end to maek a temprary Dipstick out of a tie-wrap pushed through a washer. Sorted.
I run a very rare Factory CNG powered 1999 V70.
CNGBifuel
Post by CNGBifuel »
I bought 2 x Magnefien in error follwoing advice from a 850 owner doing his.
After a flush, on my 1999 V70 AW5 I used a 3/8 in the flow line (not the return, no wiggle room). I understand the 4 speed 850 uses 1/2" line. I put one in my PAS line too. Also 3/8".
Remeber earlier cars trans flow is in reverse to later cars. Thus on mine direction of flow is from Transmission into the upper port on the radiator.
skippyxc90
Year and Model: XC90 3.2 AWD 2008
Been thanked: 3 times
Post by skippyxc90 »
I have a 2008 XC90 and planning on installing a Magnefine filter. But before I start cutting a $106 hose, I just want to ask if anyone has ever installed one of these in their 2008 XC90. I measured the OD of the pipe connected to the upper radiator and it measured 15/32. Much bigger than 3/8. I dont know the ID of the hose but any info from those who installed a magnefne filter on their 2008 XC90 is much appreciated. The rubber hose is crimped on to the pipe. The only way find the ID is to cut it.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I believe the pipe that goes in the radiator is around 1/2" at where is has the two o-ring seals inside.
Gently press both sides of the green clip against the pipe, and while keeping the clip down this way, start shacking gently and pulling the hose with some force, it will come out without issues. You'll want to have the two yellow o-rings replaced.
xc90skip
Year and Model: Volvo XC90 2008
Post by xc90skip »
After a full trans flush, I installed a 3/8 Magnefine filter on my XC90. Wow, its very tight fit. I lost some skin trying to install it. I cut the hose about 2.5 inches from where the rubber hose is crimped on the metal tube. This way, I was able to position the filter on the side of the radiator.
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 119 times
Been thanked: 15 times
Post by Jonboy74 »
Ok, I know his is an OLD post, but I'm curious what the long term / high mileage experience is with these filters?
Jonboy
Has thanked: 1505 times
Been thanked: 3818 times
I think most are trying to prevent the internal filter from plugging up and ending fluid flow. It’s a disassembly job to clean that internal filter, or the gutsy, “ drill through your case and puncture it” procedure documented in this thread
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Jonboy74 wrote: 22 Aug 2022, 23:37 Ok, I know his is an OLD post, but I'm curious what the long term / high mileage experience is with these filters?
Jonboy
From the amount of metal shavings in the pan of the 03 S80 T6 I encountered early this year when it failed I wouldn't recommend these filters. Just put several strong magnets inside or outside the pan and change the fluid once or every two years. A transmission cooler, have installed several, is a better investment.
Currently have either the 1405 or 405 on the 03 Odyssey bypassing the radiator. Have done inline in the past but after researching decided to try the bypass. Well, the radiator inlet and outlet threads to the transmission cooler were stripped so...
I have 3 to 4 Magnefine packed somewhere and I'm glad I didn't have the time to install them. If anything maybe the power steering line.
https://www.ebay.com/itm/175200706964?_ ... 1417752579
Hayden 1405.png (293.31 KiB) Viewed 655 times
MoVolvos
Post by MoVolvos »
Can use 2 brass T's and split the fluid flow if you want to use the filter. One side free flow the other side filtration.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
I was running Magnefine from 79k to 223k miles when I finally decided to rebuild the transmission. It was still driveable, but what the heck, I was inspired by the prior successful engine rebuild ;) A few cut filters showed a proof that Magnefine does catch some metallic soot. The car was either driven like stolen (when I was younger) or lately saw some wild places real up north in Canada, with half a ton of camping gear, tools, beer, etc.
I am still running Magnefine, and have it in a power steering return line as well. It is in fact cheap for what it does.
Today I've got a "good job" remark for the smooth transmission operation from an EU citizen, where they still can afford calling sh*t a sh*t without insulting others.
