Some may have read a recent post I had on this car. It had sat for 3.5 months as no one could find why it ran badly and then died when warm. I offered to take a look and replaced the Fuel pump relay and the car then ran fine.
The owner has been doing a few short runs to get confidence in it. It had been running fine until yesterday when it was 34C and it started running rough again.
Today it is only 18-20C and the car ran fine again.
I have suggested they leave it with me for a few days so I can go over the car and give them a hit list of repairs urgent to whenever.
Any thoughts what could be the issue?
A mechanic he knows swapped the fuel pump and filter (no idea what brand), and the car badly needs a PCV service.
Appreciate your combined genius guys as a hit list.
I will go through the plugs, distributor cap and rotor, plug leads and the like. I will also check the timing belt and fuel pressure in case the new pump is not what is could be.
Thanks,
97 850 Starts, runs and then gets lumpy when warm
- Has thanked: 1850 times
- Been thanked: 1712 times
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 337 times
ECT and/or connector bad/corroded?
Did the mechanic who swapped the pump used the proper submersible fuel hose in the tank?
Thanks for your suggestions Chuck. I can't answer the question on the pipe. I will ask the owner to find out assuming the mechanic knows!
