97 850 Starts, runs and then gets lumpy when warm
Has thanked: 2200 times
Been thanked: 1852 times
Some may have read a recent post I had on this car. It had sat for 3.5 months as no one could find why it ran badly and then died when warm. I offered to take a look and replaced the Fuel pump relay and the car then ran fine.
The owner has been doing a few short runs to get confidence in it. It had been running fine until yesterday when it was 34C and it started running rough again.
Today it is only 18-20C and the car ran fine again.
I have suggested they leave it with me for a few days so I can go over the car and give them a hit list of repairs urgent to whenever.
Any thoughts what could be the issue?
A mechanic he knows swapped the fuel pump and filter (no idea what brand), and the car badly needs a PCV service.
Appreciate your combined genius guys as a hit list.
I will go through the plugs, distributor cap and rotor, plug leads and the like. I will also check the timing belt and fuel pressure in case the new pump is not what is could be.
Thanks,
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
ECT and/or connector bad/corroded?
Did the mechanic who swapped the pump used the proper submersible fuel hose in the tank?
Thanks for your suggestions Chuck. I can't answer the question on the pipe. I will ask the owner to find out assuming the mechanic knows!
