Coronavirus Thread
Forum rules
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Re: Coronavirus Thread
Post by volvolugnut »
volvolugnut wrote: 24 Aug 2022, 11:40
Again, results change daily.
State growth rates for Aug 24, 2022. All information is based on reported information and actual results may be different.
For your information, the top 5 states or territories yesterday in growth rate 7 day average (the worst containment) are: West Virginia (0.190) with 576,423 cases, Guam (0.130) with 57,536 cases, Montana (0.126) with 302,455 cases, US Virgin Islands (0.125) with 22,481 cases, and Arkansas (0.076) with 925,880 cases. West Virginia has been in the top 5 states for 261 of the last 352 days. Guam has been in the top 5 states for 6 of the last 6 days. Montana has been in the top 5 states for 167 of the last 247 days. US Virgin Islands has been in the top 5 states for 57 of the last 63 days.
Several states have stopped posting new case and new death numbers. I will back calculate where possible.
A column on the right shows the previous day growth rate divided by the 7 day moving average. Red highlight states were over 2.0 yesterday. Yellow highlight states were over 1.5 yesterday. This is an early warning of higher growth rate in states. Many of these states did not report the last several days making this measure more variable for those states.
My calculated growth rate for USA is 0.0235 for yesterday, up from previous day of 0.0153. This is not population or case number weighted. Yesterday, 12 states did not report new cases. It appears some states, particularly Wyoming, are deleting active cases from the count much earlier that others. These differences in the states reporting, makes the growth rate comparisons misleading.
Daily active case counts have started to rise in the last couple weeks. There have been 118 of last 205 days with decreasing active case numbers.
There have now been 95 million total cases of Covid-19 in the US. This is 28% of the total US population. Reinfections and under reporting will distort the total number of cases.
State Growth 082422 A.png (142.13 KiB) Viewed 300 times
State Growth 082422 B.png (127.61 KiB) Viewed 300 times
volvolugnut wrote: 25 Aug 2022, 08:29
State growth rates for Aug 25, 2022. All information is based on reported information and actual results may be different.
For your information, the top 5 states or territories yesterday in growth rate 7 day average (the worst containment) are: West Virginia (0.200) with 577,475 cases, US Virgin Islands (0.148) with 22,547 cases, Guam (0.138) with 57,599 cases, Montana (0.126) with 302,455 cases, and Arkansas (0.076) with 927,072 cases. West Virginia has been in the top 5 states for 262 of the last 353 days. US Virgin Islands has been in the top 5 states for 58 of the last 64 days. Guam has been in the top 5 states for 7 of the last 7 days. Montana has been in the top 5 states for 168 of the last 248 days.
My calculated growth rate for USA is 0.0169 for yesterday, down from previous day of 0.0235. This is not population or case number weighted. Yesterday, 27 states did not report new cases. It appears some states, particularly Wyoming, are deleting active cases from the count much earlier that others. These differences in the states reporting, makes the growth rate comparisons misleading.
Daily active case counts have started to rise in the last couple weeks. There have been 119 of last 206 days with decreasing active case numbers.
State Growth 082522 A.png (108.82 KiB) Viewed 292 times
State Growth 082522 B.png (94.54 KiB) Viewed 292 times
volvolugnut wrote: 26 Aug 2022, 12:28
State growth rates for Aug 26, 2022. All information is based on reported information and actual results may be different.
For your information, the top 5 states or territories yesterday in growth rate 7 day average (the worst containment) are: West Virginia (0.210) with 578,535 cases, US Virgin Islands (0.154) with 22,561 cases, Guam (0.134) with 57,676 cases, Montana (0.118) with 304,169 cases, and North Dakota (0.089) with 263,918 cases. West Virginia has been in the top 5 states for 263 of the last 354 days. US Virgin Islands has been in the top 5 states for 59 of the last 65 days. Guam has been in the top 5 states for 8 of the last 8 days. Montana has been in the top 5 states for 169 of the last 249 days.
My calculated growth rate for USA is 0.0183 for yesterday, up from previous day of 0.0169. This is not population or case number weighted. Yesterday, 27 states did not report new cases. It appears some states, particularly Wyoming, are deleting active cases from the count much earlier that others. These differences in the states reporting, makes the growth rate comparisons misleading.
Daily active case counts have started to rise in the last couple weeks. There have been 120 of last 207 days with decreasing active case numbers.
State Growth 082622 A.png (115.46 KiB) Viewed 283 times
State Growth 082622 B.png (98.26 KiB) Viewed 283 times
volvolugnut wrote: 15 Aug 2022, 12:17
To give some context to these changes, I have calculated the average growth rate for each week back to April. The growth rate is calculated as the number of new cases each day divided by the number of active cases for the previous day. There is a typical weekly pattern of rising cases each week and falling case numbers on the weekends. I have calculated the 7 day average of the growth rate for Saturday to Friday of each week.
Using the 7 day growth rate, a calculation can be made of the number of days for the new cases to double. This calculation uses (1+Growth Rate) to the exponential of 1/X and solved for when this equation equals 2 (doubling of new cases). Variable X is the number of days to double the new cases count. I have made this calculation using 14 day and 21 day growth rate averages as well.
A graph using the average for 7, 14, and 21 days and showing the days to double new case counts for April to middle of November is below. Another graph shows the 7 day average new virus cases counts for the same period.
Inspection of the graphs show that when the line for days to double becomes flat, there may soon be a decline or increase to the count of new cases. This has happened three times since April. When the slope of the line for doubling is steep, either going up or down, there is unlikely to be a change soon in the growth or decline in new cases.
The current lines for case doubling now shows some indication of going flat soon. I expect we will see the number of new virus cases continue to increase, but we may have a change of direction starting. Perhaps the changing recommendations for controlling the virus are beginning to have an impact.
There was an error in my original logic posted on November 14. During the upward slope periods of the Days to Double graph, the actual number of daily cases are declining. I reconsidered how to resolve this contradiction in logic.
I have added a new graph with a calculation of the slope of the new case numbers (current case count minus past case count divided by the number of days). The slope of a curve is the rate of change of the plotted line. If we were plotting velocity, the slope would be the acceleration. The slope is a better representation of the virus growth because the slope goes negative when the trend in cases starts going down.
I have updated the graphs for the last week (Aug 14 to Aug 20, 2022).
The New Case Slope graph was down from the past week, and continued in negative range. The Days to Double for the 7 day, 14 day, and 21 day Days to Double were up slightly the past week. New Case Count average decreased slightly for the week. Growth Rate Average decreased for the fifth week in a row.
Stay safe out there. Don't get careless and keep up your defenses.
Growth Rate Average 082122.png (38.88 KiB) Viewed 278 times
New Case Slope 082122.png (41.15 KiB) Viewed 278 times
Days to Double 082122.png (48.21 KiB) Viewed 278 times
New Case Count Average 082122.png (22.2 KiB) Viewed 278 times
volvolugnut wrote: 27 Aug 2022, 11:27
State growth rates for Aug 27, 2022. All information is based on reported information and actual results may be different.
For your information, the top 5 states or territories yesterday in growth rate 7 day average (the worst containment) are: West Virginia (0.210) with 578,535 cases, US Virgin Islands (0.154) with 22,561 cases, Guam (0.134) with 57,676 cases, Montana (0.118) with 304,169 cases, and North Dakota (0.102) with 264,130 cases. West Virginia has been in the top 5 states for 264 of the last 355 days. US Virgin Islands has been in the top 5 states for 60 of the last 66 days. Guam has been in the top 5 states for 9 of the last 9 days. Montana has been in the top 5 states for 170 of the last 250 days.
My calculated growth rate for USA is 0.00631 for yesterday, down from previous day of 0.0183. This is not population or case number weighted. Yesterday, 47 states did not report new cases. It appears some states, particularly Wyoming, are deleting active cases from the count much earlier that others. These differences in the states reporting, makes the growth rate comparisons misleading.
Daily active case counts have started to rise in the last couple weeks. There have been 121 of last 208 days with decreasing active case numbers.
There have now been 96 million total cases of Covid-19 in the US. This is 28% of the total US population. Reinfections and under reporting will distort the total number of cases.
State Growth 082722 A.png (106.64 KiB) Viewed 266 times
State Growth 082722 B.png (91.6 KiB) Viewed 266 times
volvolugnut wrote: 28 Aug 2022, 13:50
State growth rates for Aug 28, 2022. All information is based on reported information and actual results may be different.
For your information, the top 5 states or territories yesterday in growth rate 7 day average (the worst containment) are: West Virginia (0.210) with 578,535 cases, US Virgin Islands (0.154) with 22,561 cases, Guam (0.134) with 57,676 cases, Montana (0.118) with 304,169 cases, and North Dakota (0.102) with 264,130 cases. West Virginia has been in the top 5 states for 265 of the last 356 days. US Virgin Islands has been in the top 5 states for 61 of the last 67 days. Guam has been in the top 5 states for 10 of the last 10 days. Montana has been in the top 5 states for 171 of the last 251 days.
My calculated growth rate for USA is 0.00249 for yesterday, down from previous day of 0.00631. This is not population or case number weighted. Yesterday, 53 states did not report new cases. It appears some states, particularly Wyoming, are deleting active cases from the count much earlier that others. These differences in the states reporting, makes the growth rate comparisons misleading.
Daily active case counts have started to rise in the last couple weeks. There have been 122 of last 209 days with decreasing active case numbers.
State Growth 082822 A.png (100.08 KiB) Viewed 251 times
State Growth 082822 B.png (90.46 KiB) Viewed 251 times
volvolugnut wrote: 27 Aug 2022, 11:54
I have updated the graphs for the last week (Aug 21 to Aug 27, 2022).
The New Case Slope graph was up from the past week, but continued in negative range. The Days to Double for the 7 day was down slightly the past week while 14 day and 21 day Days to Double were up slightly the past week. New Case Count average increased slightly for the week. Growth Rate Average increased for the first week in a six weeks.
New Case Count Average 082822.png (22.26 KiB) Viewed 244 times
Days to Double 082822.png (47.94 KiB) Viewed 244 times
New Case Slope 082822.png (42.96 KiB) Viewed 244 times
Growth Rate Average 082822.png (35.87 KiB) Viewed 244 times
volvolugnut wrote: 29 Aug 2022, 12:35
State growth rates for Aug 29, 2022. All information is based on reported information and actual results may be different.
For your information, the top 5 states or territories yesterday in growth rate 7 day average (the worst containment) are: West Virginia (0.224) with 580,697 cases, Guam (0.135) with 57,815 cases, US Virgin Islands (0.130) with 22,622 cases, Montana (0.118) with 304,169 cases, and North Dakota (0.102) with 264,130 cases. West Virginia has been in the top 5 states for 266 of the last 357 days. Guam has been in the top 5 states for 11 of the last 11 days. US Virgin Islands has been in the top 5 states for 62 of the last 68 days. Montana has been in the top 5 states for 172 of the last 252 days.
My calculated growth rate for USA is 0.00910 for yesterday, up from previous day of 0.00249. This is not population or case number weighted. Yesterday, 36 states did not report new cases. It appears some states, particularly Wyoming, are deleting active cases from the count much earlier that others. These differences in the states reporting, makes the growth rate comparisons misleading.
Daily active case counts have started to rise in the last couple weeks. There have been 123 of last 210 days with decreasing active case numbers.
State Growth 082922 A.png (102.84 KiB) Viewed 232 times
State Growth 082922 B.png (92.29 KiB) Viewed 232 times
volvolugnut wrote: 30 Aug 2022, 11:57
State growth rates for Aug 30, 2022. All information is based on reported information and actual results may be different.
For your information, the top 5 states or territories yesterday in growth rate 7 day average (the worst containment) are: West Virginia (0.234) with 581,638 cases, Guam (0.128) with 57,868 cases, US Virgin Islands (0.126) with 22,669 cases, Montana (0.118) with 304,169 cases, and North Dakota (0.091) with 264,248 cases. West Virginia has been in the top 5 states for 267 of the last 358 days. Guam has been in the top 5 states for 12 of the last 12 days. US Virgin Islands has been in the top 5 states for 63 of the last 69 days. Montana has been in the top 5 states for 173 of the last 253 days. North Dakota has been in the top 5 states for 5 of the last 5 days.
My calculated growth rate for USA is 0.0153 for yesterday, up from previous day of 0.00910. This is not population or case number weighted. Yesterday, 30 states did not report new cases. It appears some states, particularly Wyoming, are deleting active cases from the count much earlier that others. These differences in the states reporting, makes the growth rate comparisons misleading.
Daily active case counts have started to rise in the last couple weeks. There have been 124 of last 211 days with decreasing active case numbers.
State Growth 083022 A.png (109.6 KiB) Viewed 221 times
State Growth 083022 B.png (94.78 KiB) Viewed 221 times
volvolugnut wrote: 31 Aug 2022, 11:39
State growth rates for Aug 31, 2022. All information is based on reported information and actual results may be different.
For your information, the top 5 states or territories yesterday in growth rate 7 day average (the worst containment) are: West Virginia (0.233) with 582,666 cases, South Dakota (0.166) with 257,547 cases, US Virgin Islands (0.127) with 22,711 cases, Guam (0.127) with 57,947 cases, and Wyoming (0.121) with 174,828 cases. West Virginia has been in the top 5 states for 268 of the last 359 days. US Virgin Islands has been in the top 5 states for 64 of the last 70 days. Guam has been in the top 5 states for 13 of the last 13 days. Wyoming has been in the top 5 states for 56 of the last 64 days.
My calculated growth rate for USA is 0.0222 for yesterday, up from previous day of 0.0153. This is not population or case number weighted. Yesterday, 12 states did not report new cases. It appears some states, particularly Wyoming, are deleting active cases from the count much earlier that others. These differences in the states reporting, makes the growth rate comparisons misleading.
Daily active case counts have started to rise in the last couple weeks. There have been 125 of last 212 days with decreasing active case numbers.
State Growth 083122 A.png (117.38 KiB) Viewed 209 times
State Growth 083122 B.png (103.36 KiB) Viewed 209 times
