Is nuclear power's time finished in the US?
Forum rules
- Has thanked: 928 times
- Been thanked: 1002 times
Re: Is nuclear power's time finished in the US?
With enough good energy storage, power three months a year is good enough!
- Has thanked: 2657 times
- Been thanked: 1248 times
True, true
- Has thanked: 1506 times
- Been thanked: 3822 times
If we could release the energy fusing rubber and metal in the rear delta links we will be all set.
Q: where do nuclear scientist go on holiday?
can't wait any longer for this answer.
- RickHaleParker
- Been thanked: 958 times
In the 70s the French inventor Jean Pain came up with a composting system that will produce hot water for about 18 months before it needed to be recharged. It "waste" product is Humus . It does not produce electricity but it will provide Domestic Hot Water ( DHW ), which is about 1/3 of a house's energy consumption, and heating.volvolugnut wrote: ↑02 Aug 2022, 12:48 With enough good energy storage, power three months a year is good enough!
If you want a alternative energy project to do, DHW has the highest Return On Investment ( ROI ).
https://www.motherearthnews.com/organic ... z80mazraw/
I recall in this town in the 1980's, many newer homes had small solar panels on their roof. They were maybe 20 to 30 Square Feet. I understand they were for hot water (DHW) only. I never had one or knew much about them. I think they have all been removed.
I have read of central heating systems for towns used in Europe. The bottom of the heat cycle from a power plant is great for building heating. The drawback is the cost of all the piping.
- RickHaleParker
Because they where built by fly by night companies out of Copper pipe and Aluminum flashing which are dissimilar metals ... Galvanic Corrosion killed them in about 20 years time. If you should built one, avoid that fate.
- RickHaleParker
Anything that involves moving earth or trenching is expensive. That one of the reasons Geothermal did not catch on.
They go fission, of course......
Im here the rest of August..
Try the veal
Tip your waitress
