Help. 2 fans replaced with 1
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
GarrettB11
Year and Model: 2008 XC70
Has thanked: 2 times
Post by GarrettB11 »
In my 2008 XC70, the original radiator fan set up had 2 fans. Evidently, Volvo now replaces these with a 1-fan system. I just installed the 1-fan system myself, and it is working, but I have an extra fan plug just dangling around not being used... I'm afraid the single fan isn't going to operate at all speeds or something.
There is NOTHING on the internet about going from 2 to 1 fans, only a mountain of information about going from 1 fan to 2 or more.
Does anyone have some experience, knowledge, or advice?
Thanks so much,
-gb
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Is there something wrong with the car? Have u taken it for a longer test drive?
You might be the pioneer on this one fan idea!
BMW 540i 2002
S70 Base 2000
GarrettB11
kallekula wrote: 18 Sep 2022, 05:49 Is there something wrong with the car? Have u taken it for a longer test drive?
The radiator fan wasn't working all the time, and the radiator had a leak in it. I replaced both those, and I read that it was a good idea to change the thermostat, so I did that too.
I ordered OEM parts from FCP Euro. They are the ones that told me the 1-fan system had superseded the old (original) 2-fan system.
So far I've let the car idle for 20 min, turned on the A/C for a good while, and taken it for a 20 mile test drive. All is well. No coolant warnings. Fan is running. A/C works. But again, I just don't know if the single fan has full capability.
kallekula
Post by kallekula »
Try some gridlock traffic and see if it seems to hold up.
EDIT: attach some kind of test leads with a bulb to the fan. Pull leads into cockpit so you can see when/if fan starts. Could be wise to bring an obd reader too so you can measure temperatures.
BMW 540i 2002
S70 Base 2000
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
My XC70 friend,
We are going to need more information.
I own two P3's and both are first cousins to your car
---2010 S80 3.2 Originally came with a dual fan and it was making noise so I replaced it with a Conti/VDO Dual Fan
---2008 LR2 3.2 (I know its a LAND ROVER) Originally it came with a single fan but I replaced it with a new VOLVO Dual Fan
The single Fan is bigger than the Large Fan in the dual Fan setup (but the Big + Small fan flow more air than the single fan)
The place that you will notice loss of FAN performance first is the AC at Idle on a hot day
(the AC won't work without air flow so either you need to drive or the fan needs to work)
Questions
1. Did you replace the FAN or the Controller for the FAN?
2. What part number did you buy?
Take care
Paul
GarrettB11
Hi pgill,
Thanks for some info.
I replaced the original dual fan, which had a controller for each fan, with a single fan that has a single controller.
The part number is: VOL-31686806
Part of my concern is that, the original dual fan had 2 plugs---once at each fan controller. Now, I just have a single-fan and am using the plug that had been going to the old large fan, and the other small plug is just sitting there not being used.
pgill
Post by pgill »
Garrett,
The Dual Fan for a 2010 S80 3.2 is 31686808 (this is exactly the fan that I installed in my LR2 it even came in a nice Volvo Box)
The single Fan is in fact 31686806 which is what you have
Both of these fans should have a single controller and a single connector with three conductors
B+ - Battery Plus
B- - Battery Minus
Control wire - a small wire that sends a PWM (Duty Cycle) to the controller.
I did a quick search and I found that Volvo has used a dual fan in a S60 that has two motor controllers and it is possible that someone modified you car's wiring harness to use the fan with dual controllers.
Take a careful look at the wiring to see if has been modified. If it has then they likely just spliced into the three conductors and if that is the case then the extra connection isn't much of a concern.
Post some pictures if you get a chance.
Take care
Paul
PS I did a little more research and here is what I found.
When you removed the Old fan you were suppose to disconnect the cars wiring harness from the Fan's wiring harness at the green arrow.
But instead you likely removed the connection at the red arrow and then you plugged into the new controller and now you have extra wiring.
Just remove the extra wiring and plug directly into the controller.
pgill
Post by pgill »
Any update on the Fan?
Were you able to remove the extra wiring?
Thanks
Paul
