P80 1998 1999 2000 AWD Fuel gauge averaging (NO) or totalling(YES) ?
Has thanked: 1613 times
Been thanked: 4077 times
The Great Debate is settled by the wiring diagram
The two fuel level senders in the saddle tank senders are in fact wired in series and thus provide a single, total resistance to the CDM which imparts the fuel gauge to indicate total fuel.
See how 6/33L and 6/33R are series wired and feed into A4 and A5 on the CDM
Screen Shot 2022-09-22 at 10.33.13 AM.png (738.74 KiB) Viewed 1571 times
Screen Shot 2022-09-22 at 10.33.39 AM.png (965.88 KiB) Viewed 1571 times
Has thanked: 2215 times
Been thanked: 1853 times
That is correct, unless one or other level sensor or wiring is bad!
befarrer
Year and Model: 1998 V70 AWD
Been thanked: 24 times
Post by befarrer »
That is correct. It also uses the left tank to keep the right tank full. The total resistance is the same as the FWD P80's, therefore each AWD sender is half of the FWD sender.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I wonder if this has anything to do with the 850OBD2 app having two fuel levels. They're not the same, one is usually higher. I've always assumed it had something to do with the fuel light, but I'm not really sire of that, as the difference changes. I've also noticed that neither goes as high as they used to, which makes me think my sender is starting to get wonky.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Maestrours
Year and Model: 03/2000 V70 XC 2.4T
Has thanked: 29 times
Been thanked: 9 times
Post by Maestrours »
Hello,
Can someone please tell me what resistance correspond to what level ?
It seems that my fuel gauge is wrong (when empty it says aroynd 10 liters).
What should be the values at empty, half and full tank ?
Regards,
Cyril
Bump
PatternFlyer
Year and Model: 99 V70 XC
Has thanked: 6 times
Been thanked: 7 times
Post by PatternFlyer »
Appears to be for FWD, but the dropbox link doesn't work.
viewtopic.php?t=61820
There was another thread that I saw showing the AWD fuel level resistances, but can't find it easily.
VolvoOwl98
Year and Model: 1998 V70XC
Has thanked: 33 times
Been thanked: 17 times
Post by VolvoOwl98 »
Many thanks for this! I’ll be looking at this and comparing it to my current predicament with Saskia’s fuel gauge inaccuracies
Lifted 1998 V70XC "Saskia" - Introduction/Continuing Repair Post: viewtopic.php?t=107993
- Chassis number: 475986 (early 1998 chassis dated 01/98)
- Emission code: 4
Learning and growing all the time
PatternFlyer
Ok... I just measured the restance on the VAST pump that arrived.
When it's empty, it is 160 ohm. When it is full (float all the way up), I get as low as 4.5 ~ 5.8 at the connectors. So, it should be read in series if the fuel gauge is same on V70XC.
Totally in line with the 325 ohms reported on FWD fuel senders , as two awd senders in series would give 325 ohms
