Which older volvo do you recommend? [merged]
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Re: Which older volvo do you recommend? [merged]
Post by 454cid »
scot850 wrote: 22 Oct 2022, 09:12 2003 onward are the better FWD versions to go for.
I have read a lot about the 01-02 as being bad cars. They were afflicted with the same bad ETM's as the 99-00 P80 chassis cars. A rebuilt part will give another long life with the Xemodex contactless position sensors. The other 'bad' issue was the transmissions, again same as some of the last year 00 P80 models. The main issue is owners believed Volvo when they said they were 'sealed for life' but nobody told the oil that! Most owners also passed on the later rescinding of the sealed for life and 80,000km flush and naturally the transmissions failed with mostly bad solenoids. That or they took them for a flush at a quick lube place who pressure flushed the trans which promptly failed with moments of leaving their premises.
Passing at this age is possibly a wise decision unless you can find a manual trans.
What is an ETM? I also passed on a 2001 V70 in part because I was leery of the transmission. I've just found a P80 S70 that I want to take a closer look at, Though..... no idea of the year, and I think I forgot to take a picture of the VIN.
I've read something about the programming of the 2001 transmissions that eventually leads to failure, but maybe that only applies to P2s? Something about it shifting to neutral.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1853 times
Been thanked: 1714 times
There was. They had added some kind of idle disconnect (I may be way off base on that) in the software to reduce fuel consumption, but that led to bigger issue. Not sure why. I had forgotten about that. I do think there was a software change to fix that but naturally you would need to check. Yes it was a P2 issue as I understood it.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Electronic Throttle Module i.e. drive by wire. Luckily we don't have that little gem.
1999 V70 GLT
454cid
Post by 454cid »
Sveedy wrote: 22 Oct 2022, 13:34 Electronic Throttle Module i.e. drive by wire. Luckily we don't have that little gem.
Thank you, just found it, but haven't done any reading on it, yet.
I like my mechanical throttles.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
If you want to enter the ETM saga timewarp, here's the high-level view https://www.matthewsvolvosite.com/volvo ... le-fiasco/
Also -> Amazon link
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
2001 P2 (and maybe a couple later years) had transmission software to shift to neutral whenever you stopped in drive. It was like a early version of automatic engine shut off while waiting at a stop light. To get rid of it, you needed a dealer reprogram.
My 2001 V70 still has this original software. I never got it to a dealer to change it. And yes, it has had a transmission rebuild.
Thanks for the clarification! Sometimes (well often!!) my memory gets most of the details right but not always.
