07 s60r
Browntaa472
Year and Model: 07 S60R 02 S60 AWD
07 s60r
Post by Browntaa472 »
Got
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
Browntaa472 wrote: 11 Nov 2022, 09:06 My 07 S60R threw up 7 codes all at once, turbo wastegate solenoid low, exhaust valve and intake valve code, then 3 evap codes, this was 30 minutes after I replaced the turbo inlet, the car is hard starting, not going over 5 psi boost which should be 15, poor acceleration, 9.5 mpg, any ideas? The timing belt has cracks on it, I don’t know when the last time it was changed, but I’m thinking I maybe damaged a wiring while putting the inlet in?
Check for a blown fuse, fuse #5 in the engine compartment for earlier model year(2001-04) V70s. Not sure if it's the same for a later year S60R but I'll bet you'll find a fuse blown in the engine compartment. This fuse supplies power to the EVAP valve, variable valve timing solenoids/lvalves, turbo control valve, canister shut off valve, PTC resistor/heater so when this fuse blows you'll see a lot of codes.
Browntaa472
I
