Hy Buddies,
Some questions.
On my engine, to what the aluminum hose is connected to engine side (1) ?
On the exhaust manifold, the part N° 2 seems to be not still available at Volvo shop...
850 1995 Petrol 2,5 L 20S Exhaust manifold Topic is solved
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 129 times
It goes to the air filter box, which has a diverter door that selects between the heated air, and air from the front of the car. I removed mine due to a non-functional door.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 336 times
Is your flex joint bad on your exhaust manifold (#2)?
When I had my NA '96 GLT, that failed in me as well. I was able to find a new flex joint with a flange on it and welded it on as a replacement.
- Chuck W
I just looked it back up. The Volvo PN is 9471933.
- Has thanked: 927 times
- Been thanked: 1000 times
This is a complex weld - steel to stainless steel. It is only possible with a specific welding wire (309?) with MIG or TIG process.
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I saved my old manifold with a failed flex coupling, thinking I might replace it someday. Getting the rotational alignment right seems a bit daunting. I suppose you could assemble the coupling to the cat and the manifold to the engine and then scribe an alignment line on the two parts. Chuck, did you just eyeball it?
- Chuck W
It was 6-7 years ago. I think I made sure the flex flange was "parallel" to the head flange (made sure the bolt holes were all in roughly the same "horizontal" alignment) and burned it together. I don't recall any odd twists when mating the system back together. I also put in a new (smaller) cat at that time too.850oldschool wrote: ↑18 Nov 2022, 14:15 I saved my old manifold with a failed flex coupling, thinking I might replace it someday. Getting the rotational alignment right seems a bit daunting. I suppose you could assemble the coupling to the cat and the manifold to the engine and then scribe an alignment line on the two parts. Chuck, did you just eyeball it?
I MIG'd it with my standard wire. Didn't have any issues. Was it the "correct" way? Maybe not. Did it work? Yes.volvolugnut wrote: ↑18 Nov 2022, 14:03
I've welded other stainless parts to aluminized exhaust tubing with no issues over the past few years. I at least coat the welds up with some hi-temp paint at a minimum when I'm done.
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 620 times
- Been thanked: 143 times
I'm nort a rich guy. However, i will replace this part by a new one. Otherwise, my MVS Buddy Project would have any sense ... (to me, of course).
