850 1995 Petrol 2,5 L 20S Exhaust manifold Topic is solved
manovlov
Has thanked: 675 times
Been thanked: 164 times
Post by manovlov »
Hy Buddies,
Some questions.
On my engine, to what the aluminum hose is connected to engine side (1) ?
On the exhaust manifold, the part N° 2 seems to be not still available at Volvo shop...
Exhaust manifold.jpg (68.8 KiB) Viewed 1029 times
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
It goes to the air filter box, which has a diverter door that selects between the heated air, and air from the front of the car. I removed mine due to a non-functional door.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Is your flex joint bad on your exhaust manifold (#2)?
When I had my NA '96 GLT, that failed in me as well. I was able to find a new flex joint with a flange on it and welded it on as a replacement.
manovlov
Post by manovlov »
Chuck W wrote: 18 Nov 2022, 06:16 Is your flex joint bad on your exhaust manifold (#2)?
Good opportunity to learn to weld
Chuck W
Post by Chuck W »
I just looked it back up. The Volvo PN is 9471933.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
manovlov wrote: 18 Nov 2022, 09:54
This is a complex weld - steel to stainless steel. It is only possible with a specific welding wire (309?) with MIG or TIG process.
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
I saved my old manifold with a failed flex coupling, thinking I might replace it someday. Getting the rotational alignment right seems a bit daunting. I suppose you could assemble the coupling to the cat and the manifold to the engine and then scribe an alignment line on the two parts. Chuck, did you just eyeball it?
Chuck W
Post by Chuck W »
850oldschool wrote: 18 Nov 2022, 14:15 I saved my old manifold with a failed flex coupling, thinking I might replace it someday. Getting the rotational alignment right seems a bit daunting. I suppose you could assemble the coupling to the cat and the manifold to the engine and then scribe an alignment line on the two parts. Chuck, did you just eyeball it?
It was 6-7 years ago. I think I made sure the flex flange was "parallel" to the head flange (made sure the bolt holes were all in roughly the same "horizontal" alignment) and burned it together. I don't recall any odd twists when mating the system back together. I also put in a new (smaller) cat at that time too.
volvolugnut wrote: 18 Nov 2022, 14:03
I MIG'd it with my standard wire. Didn't have any issues. Was it the "correct" way? Maybe not. Did it work? Yes.
I've welded other stainless parts to aluminized exhaust tubing with no issues over the past few years. I at least coat the welds up with some hi-temp paint at a minimum when I'm done.
manovlov
Post by manovlov »
I'm nort a rich guy. However, i will replace this part by a new one. Otherwise, my MVS Buddy Project would have any sense ... (to me, of course).
