Hello there,
I was looking around the web for some strong twist ties (ha ha the ones that come with baggies these days are made with hair thin wire) and ran into a "remote starter" and immediately realized this could help me a lot with my car as it would allow me to start the car every day or so when i am not using it.
So the question is, is there one that would be good for this car and also would it be hard to install? I dont want to run into a nightmare of rewiring or anything like that of course, and that's probably the main thing.
Any ideas or suggestions?
Remote Engine Starter For 1998 v70
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- Has thanked: 2210 times
Main advantage is your car is pre-security chip so much easier to install.
I have a 2 way fob (lets you know it has done what you asked by confirming car has responded). I had to get an extra fob made to make it work with my 2000 R. Fobs are also re-chargeable.
The system I have is from Viper, but I have a similar but cheaper system from icarstart (who make most brands) fitted to my 4Runner. Again both work great and have a great distance they operate over. I had to pay to have them installed and they are typically around $600 CDN (about $450 US) up here. You can buy and install your own system and with your electrical and electronic knowledge you can probably do it.
- MrAl
Thanks for the vote of confidence Neil and nice to hear you had a lot of experience with these.scot850 wrote: 27 Nov 2022, 22:35 Main advantage is your car is pre-security chip so much easier to install.
Would you happen to know what is involved with installing one of these things, i mean it has to bypass the ignition key somehow that doesnt sound too easy.
I would like to say I do, but that is not the case unfortunately as I had the supplier install them. As most regulars here know electricery is not my thing. I can fault trace and simple stuff like that, but something like this I leave to the professionals. Especially on the 'R' as it is not just a starter but also an immobiliser as well.
I know there is some kind of unit needed to work around the automatic trans but other than that I don't know. I know places up here like Canadian Tire sell systems for self install so can't be too bad for someone with an electrical background.
https://www.canadiantire.ca/en/search-r ... %20starter
- MrAl
Yes i read that the immobilizer types are more difficult to do lucky i dont have that on my car.scot850 wrote: 28 Nov 2022, 07:50 I would like to say I do, but that is not the case unfortunately as I had the supplier install them. As most regulars here know electricery is not my thing. I can fault trace and simple stuff like that, but something like this I leave to the professionals. Especially on the 'R' as it is not just a starter but also an immobiliser as well.
I am getting some idea how difficult they are to install and i can see they are not what i would call easy, but it does look doable so maybe worth a shot. Just have to be careful not to screw anything up.
- Has thanked: 1611 times
- Been thanked: 4075 times
Whatever you do, document the wiring like the Good Book.
I usually quote “ sort out wiring “ at 2x labor rate , 10 hour minimum
- MrAl
Are you saying you do repairs on other folks cars too?abscate wrote: 29 Nov 2022, 14:21 Whatever you do, document the wiring like the Good Book.
That's interesting.
