I seem to recall the actual door latch on the 850 is different to the V/S70. The little plunger that is the 'lock' is a different shape/size.
You could just remove the actuator and test it on the bench. It is held on by 2 x T25? Torx screws on the outside near the latch.
- Has thanked: 1846 times
- Been thanked: 1710 times
- Has thanked: 1503 times
- Been thanked: 3817 times
Replace that hardware with cheap SS m6 bolts from Lowe Quality. You need a thin plier to hold them to get started but they won’t corrodebrunocerous wrote: ↑03 Dec 2022, 16:15Thank you for the invitation! I have mandatory kids swim team “volunteer” duty or else we would’ve been there.abscate wrote: ↑29 Nov 2022, 20:35Bring it and the kids out to port Jeff for the weekend and we will get her donebrunocerous wrote: ↑29 Nov 2022, 14:26 Ordered the new Nissens radiator and crossing my fingers that the weather cooperates this weekend.
I had just enough time before it got too dark to drain the coolant, remove the fan assembly and strip one of the screws holding the rad to the condenser. I’ll pick up replacement screws after I’m done “volunteering” tomorrow morning.
Also use SS 3/8 diameter sheet metal screws on the radiator shroud bolts. Those always rust to crap because of the radiator heat. I’ve got a link on those somewhere
Screw size links here
viewtopic.php?p=573670&hilit=Lowe#p573670
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 129 times
Yes, at that point, I'd be eliminating the latch/lock feature. The 850 hinge holds the door closed, while the S70 hinge props it out unless latched.
I'm still trying to determine if I'm actually getting power to the back. I guess swapping to the 850 setup is what I'll do if I'm not getting power back there. I'm not digging into wiring.You could just remove the actuator and test it on the bench. It is held on by 2 x T25? Torx screws on the outside near the latch.
I'm going to have to go back to the brakes, too..... passenger side, the one that stuck, is cooler than the driver's side. Also the driver's side does sweep the rotor to the edge, so there is a possibility I didn't get the outer pad perfectly in place on the passenger side. After comparing old/new pads, I thought it was just that the new pads weren't quite as wide, but if the driver's side is sweeping to the edge, that can't be it. I did go out this morning and buy a 7mm Allen socket so I can pull the pins. It probably has some air in it too, still, so I'll take care of that too.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
brunocerous
- Year and Model: 1998 V70
- Has thanked: 284 times
- Been thanked: 36 times
That’s great, thank you for the links! Of course, the bolt wasn’t stripped: the lower radiator chips had disintegrated and were just spinning. One popped out easily, while the other required grinding of the bolt without damaging the AC condenser.abscate wrote: ↑04 Dec 2022, 04:36 Replace that hardware with cheap SS m6 bolts from Lowe Quality. You need a thin plier to hold them to get started but they won’t corrode
The two vertical support (M8?) bolts are shot and had a good time spinning in place. How’d you get them out? I don’t mind using the grinder, but that seems like too tight a fit.
Hoping to find replacement clips and as many new screws and fasteners as I can find.
On the plus side, I did manage to run radiator cleaner through the system, which was probably overdue, as the radiator (Volvo/Valeo branded) appears to have been original.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- Has thanked: 304 times
- Been thanked: 517 times
I can't remember if they were regular nuts on top or some awkward shape (which they always are once corroded, but either way...) but you might be able to fit a twist style extractor socket over it.
brunocerous
Is that like one of those “Gator” multi-size sockets? I almost got one today.bmdubya1198 wrote: ↑04 Dec 2022, 15:39 … you might be able to fit a twist style extractor socket over it.
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
Brought "Ruby" the parts car home.
454cid
The Gator is the socket that looks like a spark plug socket filled with pins, right?brunocerous wrote: ↑04 Dec 2022, 18:26 Is that like one of those “Gator” multi-size sockets? I almost got one today.
I think he's talking about something like this: www.amazon.com/IRWIN-HANSON-BOLT-GRIP-E ... B0000CCXVZ
I picked this one as an example, I have no idea if this particular set is any good.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Those m8 radiator ear bolts are nasty I’ve had to drill them out on s couple of cars. There is a welded in nut thst likes to break loose and then just spin. I replace with SS m6 bolts, washers , and lock nuts; installed with verve and élan.
Yes, these sockets. I have this Irwin set, and they're very good.454cid wrote: ↑04 Dec 2022, 18:52The Gator is the socket that looks like a spark plug socket filled with pins, right?brunocerous wrote: ↑04 Dec 2022, 18:26 Is that like one of those “Gator” multi-size sockets? I almost got one today.
