Does anybody know what this broken wire/white plug is used for on a 1999 S70 GLT? It's located near the passenger side headlight, between the headlight and the wiper fluid reservoir, right in the middle of the picture below. I've noticed the wires frayed before, but they're totally broken now and while I don't drive the car much, I haven't noticed any missing features. It looks like they should go into the white plug, and then that plug leads into the giant wire bundle so I have no idea where those go. I wasn't able to see where the frayed wires go either.
I also have no idea what that open black plug is for, so any guesses on that are welcome too.
The only engine code I get is an occasional small evap code, and my main problem with the car is that it cranks for a while (5+ seconds) before finally starting. If I hook up a jumper box then it generally starts right up, so I know I have an electrical issue somewhere that I'm working to find. Probably not this tiny wire?
99 S70 GLT... Anybody know what this broken wire does? Topic is solved
- Been thanked: 4068 times
That black plug looks like the washer pump motor, do your squirts work ?
Two things live up there , headlight wipers and the alarm connection to the hood latch. You May or may not have those options
None of these will influence starting, and a 5 second crank is more likely fuel pressure than electrical. Try cycling the key three time before cranking and seeing if it quick starts then, to confirm.
- Has thanked: 2203 times
+1 Abscate hit this on the head. You have no connector on your washer pump, the 2 pins just above the wires in the picture. If your windshield washers are working I am not sure how!!
Being a 99 car, in addition to what abscate says on the fuel pump, how good is your battery? If you are not using the car much, you may want to consider using a trickle charger to maintain the battery. These cars don't like weak batteries.
rrres
- Year and Model: 1999 v70XC
- Has thanked: 12 times
- Been thanked: 34 times
Just looked at my 99, the white plug eventually connects to, I think, the washer fluid level sensor, which has blue and black wires.
The plug that connects to the black plug has black and green wires.
It's blowby
Cricket502
- Year and Model: 99 S70 GLT
Aha, that would explain it. I can't recall the last time I saw a low wiper fluid warning. My windshield wipers and wiper fluid do work, but I removed my headlight wipers after a minor front end collision that required a new bumper cover (couldn't find a cheap bumper cover with cutouts for the headlight wiper arms). I completely forgot I used to have those.
As far as the starting issue, my battery is solid and the car usually does start pretty well when it's fully charged. With this being my backup car, that's not always the case. I bought a battery charger recently to revive the completely dead battery and it has started pretty well since then, but on occasion it still hiccups and takes a while to start.
I had another thread on here a few years ago viewtopic.php?t=84095 where I never figured out the issue, but I had looked into fuel before and mostly ruled that out. I replaced the fuel filter, pump, fuel pump relay, and I think fuel pressure measured ok as far as I could tell... I also replaced the starter and made sure those connections looked good, replaced the crankshaft sensor which fixed a misfire problem but not the starting problem... Letting the fuel pump run a few times before starting had no impact. I thought turning the key and waiting 5+ seconds was helping even though I could hear the pump only running for 2-3 seconds, but that was in my head.
In the end I was thinking it had to be a bad connection somewhere, because 100% of the time when it's connected to a battery jumper the car starts right up (and strongly). I'll update that other post as solved if I ever figure out the starting issue, haha. I've got a new battery cable to try because I thought I remembered some strange measurements with my multimeter on the negative cable.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I was under the hood changing a headlight bulb, in my 99, and recalled this thread. I have that white connector, but I don't have that plug next to the washer fluid filler neck. It's more of a white-ish plastic depression.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 1829 Views
Last post by Ozark Lee
- 635 Views
Last post by beigg
- 1873 Views
Last post by bmdubya1198
- 1007 Views
Last post by ljsommar1
- 1160 Views
Last post by Roger_850T
