98 v70: power steering fluid issue Topic is solved
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: 98 v70: power steering fluid issue
Post by MoVolvos »
Per abscate recommended method. Any Synthetic Multi-Vehicle ATF will do. My personal experience and choice in order Swepco 714 20wt (non synthetic in 98 & 00 S70), Havoline, Wolf's Head transmission fluid.
MoVolvos
Post by MoVolvos »
scot850 wrote: 21 Dec 2022, 16:41 This may help. Check figure #6 in their pictures. They state the metal line is the high pressure line, the the rubber hose is the return.
https://www.pelicanparts.com/techarticl ... cement.htm
Pelican has an excellent set of articles for the C30. Purchased the front set of KONI STR.T from them earlier in the year for the 08 C30. Purchased the Swepco motor oil from them also.
