That's a Borbet and looks a Volvo OE rim?
1999 V70 Oblong holes on wheels
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Re: 1999 V70 Oblong holes on wheels
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
No tire shop would dare touch that wheel.
Torque sticks aren't meant to replace a torque wrench. The proper use case would be using them to run the lugs in without overtightening. Then you would still use a torque wrench to tighten to spec. They really aren't meant to be more accurate than +/-20%. There's also a lot of scientific evidence that shows torque sticks only work on pneumatic impact guns and are useless for electric.
Knows enough to be dangerous
- Has thanked: 1506 times
- Been thanked: 3818 times
If the holes are still circular on the outside face of the wheel, the lug bolts will center the wheel on the hub. If not , the wheel is scrap.
They aren’t hard to find used for $50 or so
Ooops, ghosted Lugnut
veto using them if they do not have good, uniform, round holes on the front side that the lug bolt can fit tight. Over size and out of round bolt pattern will not center well on the hub, places bending stress on the bolts, and may work loose. I don't trust them for anything.
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
I agree with Dr. Abscate, and as @What... mentioned, those festive colored things at the tire chains are not ideal.
Left unsaid in the original post is whether this is one instant example or if all four wheels are like this.
PM sent.
PM sent.
Whats a Borbet? Is it related to a Henway?
- MoVolvos
No way, more related to B BS.
- foggydogg
Barbet gone bad: Marine Aviator: " You can not !"
Navy Aviator: "Betcha I can ! Lend me your Herc, and hold my beer."
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
EDIT....Oh crap! I had no idea.
"Full stop in 267 feet at 85,000 pounds."
"With maximum load, the Hercules used only 745 feet for take off."
How long is the launch deck area on these?
How fast is that ship going, and what was the headwind?
- 9 Replies
- 1598 Views
Last post by benrk
- 207 Views
Last post by securisign
