As the title says, but it is time. I don't want to turn her over to my 16yr old and don't want to use her for traveling long distances. I posted this on a few other Volvo Forums. Most comfortable car I have driven. I am the 3rd owner for about 6yrs. 2nd owner had it for a month before getting into a 850R project. I have all the records for service, maintenance and replacement parts. I can list them out if needed. timing belt, fuel filter, brakes, rotors, oil change every 3k, new front shocks for Halidex system, power steering pump etc.
Only local Volvo mechanics and dealership have worked on it. The R has 190k and still runs strong. It is in my garage and I typically drive it locally a few miles each week. Magic blue metallic exterior that has typical rock chips, a few scratches and some fading on the front bumper. The roof has 2 spots that look like it had a touch up by the previous owner who had a rack on it.
Nordkap Leather is clean and none of it is ripped. I installed PIA fog lights, new Sony stereo unit by a local center and previous owner installed IPD sport exhaust. I am manic on detailing and keeping my vehicles up to service and always kept this one going with what was needed. No codes, airbag recall installed so that is why on the steering wheel there is no R logo.
I am in Florida outside of Orlando and we did not get any flooding or damage so this car is clean and have title in hand.
No prior accidents or issues. A/C and heat blow cold and hot. New battery just installed. I have many pictures posted and can send more. Very clean and recently serviced at Maitland Importers Orlando FL.
Feel free to reach out with any questions. looking for $10,500 or best offer.
Service History here.
2005 Volvo V70R Vin# YV1SJ527252482263 VEHICLE HISTORY 2017-2022
All work performed at Cech Brothers Volvo/Lexus Specialist, Winter Park, FL also Volvo Store, Winter park FL
2017- Purchased from private party June 2017 miles 110,700 as is condition.
3 oil changes synthetic blend 5/30 every 3k
Full tint on all windows and front windshield
10-23-2017- Timing belt, Idler Pully and tensioner replaced 120,829 miles
2018-
2-14-18- safelite new windshield and parts, 2 brake rotors pads , oil change
4- oil changes synth blend 5/30 every 3k
11-5-2018 – replaced 2 control arms
Drivers side window motor adjusted and replaced
2019
Wheel alignment and rotate tires
9 oil changes synth blend 5/30 every 3k
2-7-2019- installed 2 new Monroe 4c shock/struts and uppers from IPD, Brembo brakes purchased
3-26-2019- replaced front pads and rotors
3-12-2019- fuel filter replaced, axle assembly, replaced 1 cv axle left
4-24-2019-= air mass meter replaced
4-15-2019- replaced fuel pressure sensor
6-4-2019- A/C compressor removed and replaced, ac system charged, front right axle assembly replaced
7-17-2019- Adjust AC clutch Gap and ac recharge service-
9-18-2019- replaced rotors and pads again and went from Brembo back to OEM
12-2-2019 – axle shaft assembly replaced, thermostat removed and replaced.
2020
4- oil changes synth blend 5/30- every 3k. also air filter etc.
Air cleaner element replaced
4-29-2020 replaced main radio unit with Sony
6-19-2020 – ABS sensor and left front suspension ride height sensor replaced
9-30-2022-rt front headlight ballast replaced. Both headlight bulbs replaced
9-5-2022 4 new Hankook Venus V12 tires, rotate balanced and road hazard- 178583
2021
3 oil changes synth blend 5/30
4-6-2021 brake fluid flushed and replaced
1 new OEM Pegasus Rim
2022
2 oil changes synth blend 5/30
1-25-2022 Air bag recall performed and replaced.
2023
1-2023 Oil change and air filter change
Right Engine Mount removed and replaced OEM
Torque strut replaced OEM
OEM Accessory Drive Belt replaced
Front brake pads and rotors replaced
Power Steering unit replaced and system flushed( Not pictured in the engine bay picture) the pic was before replacement
2005 Volvo V70R- Magic Blue with Nordkapp -- 191K and $10,500 or best Topic is solved
Kplantv70R
- Year and Model: 2005 V70R
- 20221003_163338.jpg (661.41 KiB) Viewed 1725 times
- 20221003_163442.jpg (417.9 KiB) Viewed 1725 times
- 20221003_163610.jpg (446.78 KiB) Viewed 1725 times
- 20221024_165635.jpg (648.11 KiB) Viewed 1725 times
- 20221123_121711.jpg (459.17 KiB) Viewed 1725 times
- 20221123_121807.jpg (447.56 KiB) Viewed 1725 times
- 20221123_121822.jpg (473.69 KiB) Viewed 1725 times
- 20221123_121921.jpg (511.13 KiB) Viewed 1725 times
- 20221123_121926.jpg (288.24 KiB) Viewed 1725 times
- 20221123_122006.jpg (400.03 KiB) Viewed 1725 times
- 20221123_122009.jpg (367.38 KiB) Viewed 1725 times
- 20221003_163629.jpg (643.71 KiB) Viewed 1683 times
- 20221123_121812.jpg (313.16 KiB) Viewed 1683 times
- 20221123_121842.jpg (505.88 KiB) Viewed 1683 times
- 20221123_121915.jpg (503.14 KiB) Viewed 1683 times
- 20221123_121949.jpg (479.83 KiB) Viewed 1683 times
- 20221119_105252.jpg (484.68 KiB) Viewed 1683 times
- 20221123_121721.jpg (403.22 KiB) Viewed 1683 times
- 20221123_121729_01.jpg (400.45 KiB) Viewed 1683 times
- 20230120_133606.jpg (433.32 KiB) Viewed 1683 times
- 20230120_133626.jpg (575.4 KiB) Viewed 1683 times
- 20230120_133644.jpg (397.64 KiB) Viewed 1683 times
- 20230120_133646.jpg (376.18 KiB) Viewed 1683 times
- 20230120_133648.jpg (437.08 KiB) Viewed 1683 times
- 20230120_133714.jpg (442.33 KiB) Viewed 1683 times
- Has thanked: 1502 times
- Been thanked: 3817 times
Beautiful, worth every penny.
Is that a two or three pedal R?
- Has thanked: 1846 times
- Been thanked: 1710 times
Hard to tell, but as it has a gearshift gator it looks like an auto and not the 'spaceball' manual shifter:
https://www.ebay.ca/itm/194022550325
Kplantv70R
Sorry all it is an automatic. I have more pictures I can post if requested, think only a few fit on here.
Kplantv70R
Just added more and feel free to reach out with any questions.
Kplantv70R
The V70R has sold!!!
- Oly850
- Year and Model: In acquisition mode.
- Has thanked: 53 times
- Been thanked: 22 times
My son has a silver 2007 V70 with the 2.4 Turbo, but lord yours is (was) remorselessly clean. Very nice car definitely shows you cared about it.
Looking for a V90 to be my next Volvo, at the very least a T5.
2017 XC90 Inscription - My best Volvo by far, but Ex-wife departed & I had to sell.
2001 S80 T6 - rebuilt trans, head gasket, fixed & sold
1997 V70 - kid car, sold
1996 850 GLT - found under bridge, 2 year refurb project, commuter car, kid car, T-Boned - SIPS saved passenger. Totaled.
1997 VW GTI VR6 - exceedingly fast.
1971 VW Type II/231 - it was pointed out by management that the children would be killed in it.
Beautiful car and kudos to new owner
In 2005, some paid $1250’to delete the M66 and replace it with an AT
I bet bdub is crying with me over that……
The first step is to stop spamming Fora but SFS will handle that for you automatically now!
- Has thanked: 2652 times
- Been thanked: 1245 times
Sorry, had to nuke the user/his four posts, so your post is out of context, but here it is for posterity:
leandrotrossard » October 3rd, 2023, 7:43 pm
I am interested in purchasing the 2005 Volvo V70R you have listed. Please let me know the next [deleted the spam link ] steps to proceed with the purchase.
