Pretty sure there is suppose to be a vacuum line there. The question is where does it go? That's a wiper blade attachment piece
Hi,MoVolvos wrote: 01 Mar 2023, 20:40 *
Pretty sure there is suppose to be a vacuum line there. The question is where does it go? That's a wiper blade attachment piecedon't pay attention to it
That's a good explanation of how it works. I don't think your method of testing will work, Though. The pump produces pressure, not vacuum. You would need something like a hand held Mighty Vac vacuum pump for testing.MrAl wrote: 02 Mar 2023, 01:19Hi,MoVolvos wrote: 01 Mar 2023, 20:40 *
On my car, the 1998 v70 non turbo, that contraption that pipe is connected to is the vacuum actuator that opens and closes that flap you see in the big opening that is blocked up. That little pipe connects to the other side of the air box at another little pipe through a vacuum line. That other little pipe on the other side seems to be the thermostat. The thermostat senses temperature inside the air box and opens and closes according to temperature so the flap can open and close. The other side of the air box also has another little pipe on the thermostat that connects to the main vacuum line i believe.
The way it seems to work is the vacuum is always present but is only allowed to reach that vacuum actuator when the thermostat allows it which adjusts the flap (you have blocked up in the picture) to regulate the air temperature inside the air box.
As the flap opens or closes or is part way closed, it allows some fresh air in from the front port or takes in air from the manifold heater part in the back of the engine. The combination of fresh air and heated are is what ends up getting into the air box and so the air box temperature is a mix of fresh and heated air.
That seems to be the way it works on my car. I never got to test the regulation temperature yet though. That can probably be done if you have a spare thermostat. You can run an air line from an aquarium pump to the thermostat and heat the thermostat until it lets air through it. I got an air pump but that was after i reinstalled the air box so i didnt get to test it yet and i dont have a spare thermostat.
Here's a rough schematic...
MainVacuumLine----->-----Thermostat----->-----VacuumActuator----->-----Flap
Hi,454cid wrote: 02 Mar 2023, 09:53That's a good explanation of how it works. I don't think your method of testing will work, Though. The pump produces pressure, not vacuum. You would need something like a hand held Mighty Vac vacuum pump for testing.MrAl wrote: 02 Mar 2023, 01:19Hi,MoVolvos wrote: 01 Mar 2023, 20:40 *
I did temporarily use aquarium air line for one of the connections on my 850.
Hello,abscate wrote: 03 Mar 2023, 00:59 You can’t mimic vacuum by applying pressure to the opposite port. You would have to apply it up the opposite side of the motor diaphragm, which has no port to access.
See links above.
We have almost never seen failures in the actual vacuum actuator or the air cleaner box thermostat, just vacuum lines or the elbows seem to be the maintenance spots.
