DIY: 1998 S70 GLT Documenting Vacuum Hoses [Turbo]
This topic is in the MVS Volvo Repair Database » Vacuum Lines on Turbo 1993-2000 850/S70/V70/XC70
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
DIY: Documenting Vacuum Hoses
I just want to dedicate a thread strictly to photographing the vacuum lines in these aging Volvos.
As the car gets older, vacuum hoses break and people are always asking for diagram. The problem with underhood sticker is that: it looks good on paper but it has its limitation, i.e., no real photos.
I just spent 1h photographing different vacuum lines of my 1998 Volvo S70 GLT.
If you have other photos, please annotate them with arrows/caption etc. and post them (especially those with blue silicone hoses lol…).
>>> Looking for non-turbo vacuum hose diagrams? <<<
Please state your year model when posting photos, this way people know which car it came from!
The best way to handle this project is to get an assorted mixture of vacuum hoses at local parts store. I don’t remember the exact size of each hose, but since these vacuum hoses are so cheap (a few dollars for 6 feet), just get different sizes b/c you will need it later for something else. Just drive the car there and the people at the parts store will help you get the correct sizes.
1. General Photo of my 1998 Volvo S70 GLT:
2. This hose I lable #3 is tricky, it connects to port #3 in I.M. to this location at the Turbo:
3. This hose goes to FPR, it connects to the small metal pipe behind the engine. Please see this excellent DIY by jreed:
https://www.matthewsvolvosite.com/forums ... hp?t=54895
4. This solenoid has a T-connector: 1 end goes to Rubber Boot (arrow), the other end goes to Turbo (dots + arrows):
5. SAS system. I shows the photo here but I already did the “SAS Delete” using the 99-cent Radio Shack diode:
6. This T-connector provides vacuum to:
- EVAP Solenoid
- The port near the PTC Valve (Yellow Arrow)
7. The vacuum hose starts at the (R) side of the I.M. ---> PTC nipple. Please the PCV DIY by jblackburn and cn90:
https://www.matthewsvolvosite.com/forums ... hp?t=28487
https://www.matthewsvolvosite.com/forums ... hp?t=53448
That is all for now, anyone with more photos, please add to the collection to help others keep the old beasts going…
Reason: added "Turbo" to title for SEO reasons
Post by cn90 »
For reference purpose, this excellent thread has some diagrams:
https://www.matthewsvolvosite.com/forums ... php?t=6941
RumpusRoom
Year and Model: 95 850 turbo
Post by RumpusRoom »
This is great!
Post by cn90 »
Another vacuum hose I forgot to mention is the hose from the solenoid ---> bottom of turbo (YELLOW arrow).
This hose is difficult to get to from below but with some patience (and long needle-nose pliers), you should be able to do it:
deepsouth
Year and Model: 2001 Volvo XC70
Been thanked: 11 times
Post by deepsouth »
This is great information. But I'm not sure where this hose goes. It leaves the manifold, runs under the throttle body, under the air box (where mine is joined by a plastic connector) and then heads under the fuse box towards the booster. It very rotten. Any ideas?
Eric
Heads towards firewall.
Plastic connector. (Underneath Air Box)
This is the hose in question.
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
Post by cn90 »
@deepsouth,
I think it is for Brake Booster.
http://volvospeed.com/vs_forum/topic/51 ... e-booster/
I borrowed the photo from crazykn and repost them here:
deepsouth
Post by deepsouth »
cn90 wrote:I think it is for Brake Booster.
Yup. That's it! That was my hunch but the other end is a real PITA to see, let alone get to. Perhaps the reason for the plastic connector?
Eric
2001 XC70, 129,000
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
FYI, here is a post with similar info for non-turbo versions:
https://www.matthewsvolvosite.com/forums ... =1&t=65002
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
cn90 wrote:Another vacuum hose I forgot to mention is the hose from the solenoid ---> bottom of turbo (YELLOW arrow).
I noticed this hose (solenoid to turbo) when I was replacing the turbo coolant lines is soaked in oil. Should I change it or if it was leaking it would throw a code correct?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Post by erikv11 »
If torn yes, but if the line is spongy and leaky but not torn, then it will not necessarily throw a code. Boost control may be a little sluggish, though.
Generally speaking, it is much more efficient to just get in there and replace all of the lines. The rubber is coming up on 20 years old, even if the engine bay was kept clean it may be getting crumbly just from drying out etc.
