upDATE5: 99 s70 silver awd turbo auto PARTS fs (bulk too), Antlers OK Topic is solved
- CIK7
- Has thanked: 329 times
- Been thanked: 87 times
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Just remembered this.
https://www.facebook.com/marketplace/pr ... 5003190461
Purchased a set of 4 complete door cards from Jonathan, if I recall last year for my Project 2006 S60 2.5T. He told me that he receives a shipping discount when purchases are processed through FB. We negotiated a price and he changed it on the FB page and like eBay went through with the transaction directly on FB. Shipped from Aurora IL to NC for $28. He purchase 2 large boxes and I think shipped using UPS.
May want to consider looking into this and selling to MVS members or others through a FB Marketplace Acct to receive what I consider a "FB Subsidized" shipping cost.
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
As I suspected, stumbled across pics from the last time I had the pleasure of removing a P80 shaft; I remembered right, red thread locker.CIK7 wrote: ↑23 Feb 2023, 11:33 Abscate I've ran into a hexa problem also known as the Allan screws that join shaft to rear differential. I tried a 6mm too big. 5.5mm to small. 1/4" too big. Next one down too small. Will you accept it if I cut the shaft close to the diff? Someone is bound to have the right tool.
Heat plasticizes the locking goo, way easier to get them loose with a good 6mm allen.
This is what I use, smaller and much easier to get into tight spaces, really localizes the flame point
https://www.harborfreight.com/butane-mi ... 63170.html
- CIK7
Bump
- foggydogg
- Has thanked: 1506 times
- Been thanked: 3822 times
I’ll take some of those trim pieces off your hands. Will reach out on Pm. Crazy week at work and emptying apartments this week too, so hold until weekend please.
- CIK7
I got sort of a torch. A direct blue flame candle lighter. Now I need to figure out the allan wrench. Perhaps cleaning out the head.
- Has thanked: 1853 times
- Been thanked: 1714 times
Soak the bolt heads with PB Blaster/Liquid Wrench or whatever, and then it is a laborious case of laying on your back and using a straight sharp pick, cleaning the allan heads out until the allan wrench fits nice and snug. You may have to tap it in with a hammer. I used a 3/8" drive allan socket and a wobble drive with a long brake bar on it. If you can reach the ends of the bolts make sure they are clean and lubed as well.
- CIK7
I forgot to soak most of them with lube. Got a light to shine on bolts while I unscrewed first one. There was no crud in the heads but #6 still did not fit. 5.5 was obviously too loose and 7 was obviously too big; 1/4" was also too big. However, I discovered that a T40 was perfect fit. Got all bolts out. Got the driveline bearing support and support plate unbolted. No matter how I wiggle the shaft in/out or even lowering the driveline support, the shaft will not come out from either end of the car.scot850 wrote: ↑30 Mar 2023, 23:07 Soak the bolt heads with PB Blaster/Liquid Wrench or whatever, and then it is a laborious case of laying on your back and using a straight sharp pick, cleaning the allan heads out until the allan wrench fits nice and snug. You may have to tap it in with a hammer. I used a 3/8" drive allan socket and a wobble drive with a long brake bar on it. If you can reach the ends of the bolts make sure they are clean and lubed as well.
