MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
P80GLT wrote: 09 Apr 2023, 09:47 @ MrAl, Yes I have my own lift, I built the garage in 2008 nd had planning permission for a pit, but when I excavated the hole it filled with water due to the height of the water table, so I filled it in and installed a lift...
Old filter removed this morning and left to drain again for another hour, new filter primed and fitted, sump plug refitted with new washer, 5.3 litres of Castrol 10W-40 A3/B4 poured into the engine, checked for leaks and sump cover refitted, service light reset and we're ready for another summer, bring on the sunshine
Wow, pretty amazing setup you have there.
Do Volvos float? I'll drive my car over there to work on it also (ha ha).
Actually that might not do me much good because i hate to have to stand under those things. One of the garages near here that did an oil change for my Volvo one time has one similar, and when the oil was being changed i stood clear of it.
That's amazing though that you have one at home. I guess if i had one i would end up using it too.
Back when i had a garage i installed a manual hoist so i could do an engine rebuild, 390 cu in Pontiac.
Thanks for the pic of the garage that's really cool ... made my day :-)
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
P80GLT wrote: 08 Apr 2023, 23:44 Took the 850 for a drive to warm up the oil
None of these are real. These pics are from 1998.
BlackBart
Post by BlackBart »
My garage was originally an open carport, so a barely reinforced thin slab that can't take the loads of a 2-post lift, then a ceiling that would crush the top of the car at every oil change..... I'll live with my jack stands.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
Drove the 850 to church today. Recalled a funny that happened yesterday. The new car wash I take my vehicles to now, has nice self service vacuums, and compressed air (for blowing dirt out of crevices). I was able to get the 1/4 cookie out of the car that I dropped in between the center console and seat... like 6 months ago! I just couldn't reach it, and it bothered me since I never got to finish eating the cookie! No, I didn't finish eating it!
Thankfully, mice never got in the car, while it was sitting.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
454cid
Post by 454cid »
BlackBart wrote: 09 Apr 2023, 12:07 My garage was originally an open carport, so a barely reinforced thin slab that can't take the loads of a 2-post lift, then a ceiling that would crush the top of the car at every oil change..... I'll live with my jack stands.
My garage is full of stuff... parts, and tools, and yard equipment. No room for a car. The floor is also quite cracked. I actually had termites come through a crack and eat a cardboard box which I thought was interesting since this isn't the south.
I've taken to using plastic ramps if I need to get under a vehicle and don't need the wheels off. The plastic ramps don't seem to push on the concrete like the old steel ones tend to do.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Has thanked: 1503 times
Been thanked: 3817 times
I’ve got plastic Ramps and I really have to decide what’s a reasonable end of life for them. Unlike metal , they will fail suddenly without signs of polymer fatigue.
5 years, 10 years ?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
BlackBart wrote: 09 Apr 2023, 12:02 None of these are real. These pics are from 1998.
You would think so!
I'm trying to find the best deal on a 2 post lift for my shop right now. I've needed one for a while, but I think it's finally time to pull the trigger. I've been eyeing an Atlas BP8000 or 9KBP.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
When I built my garage the plan was to build a pit into the floor, however once I excavated the hole for the pit it soon filled with water which indicated I was below the water table level so I backfilled the pit and spoke to my architect. After a bit of head sctatching we decided I could fit a lift once the build was completed (plans were already approved and changing them mid way through would be a major headache and hold the build up for months). This meant fitting extra roof trusses in the roof space where I intended cutting into for the extra height. I fitted extra trusses and once the build completed and passes by planning I went to work bolting in extra timbers that would allow me to remove the bottom stings from the trusses. A tense nerve racking time was had in the roof space with saw in hand cutting my trusses waiting for the roof to crash to the ground. It's been like that now for 12 years and no problems.
Maximum lift height before cutting trusses
Truss strings before cutting
Extra timbers bolted in and strings cut away
XC90 on the ramp and too high for me to reach
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
454cid
Post by 454cid »
abscate wrote: 09 Apr 2023, 13:14 I’ve got plastic Ramps and I really have to decide what’s a reasonable end of life for them. Unlike metal , they will fail suddenly without signs of polymer fatigue.
5 years, 10 years ?
I'd think they'd last a very long time. Mine are probably 15 years old now. They're not hollow, but gusseted on the inside. If they were to let go, I'd expect that to happen as I was trying to drive up them. I did have a very old pair of riding boots (motorcycle) that crumbled with handling after having sat for a very long time.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
Is your ceiling modified to accommodate the car lift?
