Excellent advice.yanga001 wrote: 08 Apr 2023, 12:00 I usually do not trust a word of the owners. I've been told by people that a volvo has a timing chainand didnt need a timing belt service by a seller. They really do not know.
In my experiences interviewing people during my job, I found the following.
Most people do not know exactly what they are talking about, and will get defensive/uncomfortable with too many yes/no or technical questions. My usual strategy is to examine the car thoroughly with ramps, a scanner, and perhaps a jack. Always explain to the seller what you are doing to the vehicle as you examine it. Some people may think your code scanner is "stealing the car", not many but some.
Take the vehicle for a test drive for sure, and explain to the seller who should be with you, what you are doing. If you are going to floor it then let them know before hand. If you are checking how it tracks by releasing the wheel then let them know.
When you ask the seller for information on the vehicle, try to do it over the phone or in person. People can say a lot more without thinking hard on it versus a well tailored text/email.
I think I’m gonna buy this… unless you guys strongly disapprove
- Has thanked: 2856 times
- Been thanked: 1332 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I was thinking O2 sensor, since that's what mine did. ECT seems like a plausible explanation, too.scot850 wrote: 08 Apr 2023, 08:35 But surely if she gets it tested, that is a good thing? At least you both know what is wrong with it and can negotiate from there. Like I mentioned earlier, many owners get 'forgetful' about issues with their vehicles when it comes to selling. Black soot could be it is burning oil from worn valve seals, or ECT is bad.
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2199 times
I would expect a bad O2 sensor tho throw a code, but it is also a good suggestion.
454cid
My 850 took forever to set a code. When I reset it, it did not come back very quickly, if at all. It was like the ECM wasn't realizing it was a false reading. It just kept dumping fuel in, trying to lift the O2 voltage, all the while the exhaust was so rich it was getting soot on the paint.scot850 wrote: 08 Apr 2023, 13:23 I would expect a bad O2 sensor tho throw a code, but it is also a good suggestion.
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Good to know!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Mine was doing that too.454cid wrote: 08 Apr 2023, 15:13My 850 took forever to set a code. When I reset it, it did not come back very quickly, if at all. It was like the ECM wasn't realizing it was a false reading. It just kept dumping fuel in, trying to lift the O2 voltage, all the while the exhaust was so rich it was getting soot on the paint.scot850 wrote: 08 Apr 2023, 13:23 I would expect a bad O2 sensor tho throw a code, but it is also a good suggestion.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
I'll caution against a 2004 XC70 and likely 01-03 XC70 as well. I knew one where the angle gear stripped out, eliminating the AWD capability. I seem to recall that it was a common problem for 01-04 but do research it further. The XC70 got a facelift in 2005 so I assumed they improved the AWD at that point.
FireFox31
Kesha scored an awesome one owner S70T5 so I think she is set.
- 13 Replies
- 2376 Views
Last post by misha
- 935 Views
Last post by jonesg
- 56 Replies
- 17049 Views
- 733 Views
Last post by outrigger777
- 14 Replies
- 3621 Views
Last post by bmdubya1198
