You have to pry is out of the end caps. I use a flat blade screwdriver and mallet to tap between the shaft end and the cup on the V/C end and the angle gear ends.
Good Luck!
upDATE5: 99 s70 silver awd turbo auto PARTS fs (bulk too), Antlers OK Topic is solved
- Has thanked: 1853 times
- Been thanked: 1714 times
Re: upDATE5: 99 s70 silver awd turbo auto PARTS fs (bulk too), Antlers OK
- CIK7
- Has thanked: 329 times
- Been thanked: 87 times
I'm sorry to disappoint y'all. I can't do it. I want to be done with this car and get it outta here. I'm going to send it off today or tomorrow.
- CIK7
Please let me know soon (today or tomorrow) what parts you want to salvage. I will do my best to help you. Have piled stuff on top of the door cards in the parts car.
Are the engine and trans already pulled? If so, disconnecting the angle gear and bolts at the VC to rear diff and just drop the whole lot and let someone else deal with the separation.
- CIK7
I am working on dropping the whole front subframe. The driveshaft is unbolted on both sides. Rear shaft cover is off. Front one won't budge by prying or chiseling with a flathead screwdriver. I suppose it would disconnect if I drop the subframe and then pull out from under front end with a chain.
- CIK7
While I'm at it, I can sell off the cylinder head and turbo.
Good luck with all that work! Makes me feel tired just thinking about it!
- CIK7
That's exactly how feel. Don't even want to do anymore but hopefully it works.
I am avoiding pulling the dash to repair the mounts. Been avoiding that for 3 years at least!! Maybe next week.........!
- CIK7
yeah the dash on the parts car had already 75%disconnected from firewall. It wiggled a lot when I removed the upper dash panel. The dash on the rotten tomato squeaks a bit but not bad.
