Mangefine Filter Installed w/ Pictures
This topic is in the MVS Volvo Repair Database » Mangefine Filter Installation Tutorial w/ Pictures
Geevs
Year and Model:
Has thanked: 9 times
Post by Geevs »
Hi all, I had my mechanic install a Magnefine filter (metal housing) among the other things he was working on my 2006 V70R. When I drove the car home, the tranny seems normal but when I got home to re-check his work I noticed he installed it backwards i.e. the flow arrow is pointing towards the upper tranny cooler connector in the radiator. Would it be OK to reverse the filter so that it flows in the correct directions? Just want to know if I can reuse the filter or need to replace it with a new one. It's been used less than 100 kms. Thanks.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Yes, can reuse it.
Geevs
Year and Model:
Post by Geevs »
Good to hear, thanks!
Geevs
Year and Model:
Post by Geevs »
Would reversing the filter dislodge the dirt already trapped by the filter since the flow is now pushing in the opposite direction?
vtl
Post by vtl »
Geevs wrote: 02 May 2023, 08:25 Would reversing the filter dislodge the dirt already trapped by the filter since the flow is now pushing in the opposite direction?
The paper media does not filter much. ATF does not really have anything for paper to filter, unless the transmission is on its last leg. What the filter is really good for is trapping soot sized magnetic dust.
Don't overthink it, just put it in correct direction and done.
