Digital Caliper Suggestions & Cost
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
How many of you have gone to a digital caliper, either for accuracy or because it's so much easier to see?
I'm tired of squinting through reading glasses at a dirty scale. And I don't trust the numbers. But I'm not going to spend $250 on a precision machine shop tool I use now and then.
Suggestions?
Brands?
Cost range for good quality? A random Amazon search shows me some nice Mitutoyo brand. Then the next one down is $19...brand Z.
Thanks -
BlackBart
Post by BlackBart »
This is 20 minutes long - sorry. But he's smart and makes sense. If you drop things all the time and need rough dimensions, get a HF. If you run a business where accuracy is important and customers will note your use of quality tools, get the good ones. But he says if you need real accuracy, you should be using a micrometer anyway. .01 or .02 mm is "pretty damn close" in anything I would be doing. I'm not rebuilding an engine with it.
I do need it to be accurate, and I do need to be able to see the numbers quickly.
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
Another route is used measuring tools of good brand names. I have a couple of these I trust. I also have several actual micrometers and gauge blocks for checking. However, all of these tools were purchased used - some at swap meets and others at pawn shops.
A very handy tool to measure a varying dimension is a dial indicator set up on a magnetic base. I have a couple of these.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I'm always on the look out for Starrett tools. Very high quality.
1999 V70 GLT
BlackBart
Post by BlackBart »
Good idea lugnut - I checked my Craigslist and there were zero. But there are several pawn shops around to check.
That 6” Shars is about <EDIT, $35>, I’ll check on Starrett.
Brown and Sharpe is another excellent US made brand. There are also great Japanese brands.
BlackBart
Post by BlackBart »
I found some $500 Japanese calipers (!). Are they laser??
I have two of those old sheet metal calipers in the drawer with measuring tools. They’re darn good at telling you the difference between a 3/8” bolt and a 1/2” bolt. Which is often enough. When I get down to mm and I’m using a magnifying glass to count marks, I get frustrated.
