Transmission codes
misha
Has thanked: 152 times
Been thanked: 402 times
Re: Transmission codes
Post by misha »
Doesn't matter as long as it's correct for your car.
Usually the "T" number is matching with production year of a car.
This picture is from a parts car...'96 2.5 20v:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Good call.
If you dont mind i would want add link to this topic in there if detected this fault code and it doesn't make sense after checks..?
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
Hey, I have been driving the car more now, and noticed something odd to me. The fuel consumption has gone up quite a bit (~1.5L more or 2mpg less), and I do not notice the lock-up clutch engaging any more. before I could definitely tell it was going on/off, probably somewhat similar to the non-turbo table.
Do I understand this table correctly, that in my turbo it will only lock up past 129mph? Which would be 207kmh - much more than we are allowed to drive here. So it will never engage for me if it is working correctly, and it did not work right before I replaced the TCU...?
850 T5-R '95 auto Image
Has thanked: 1502 times
Been thanked: 3817 times
I suspect those numbers are kph, not mph as labeled
hausmeister
abscate wrote: 05 May 2023, 05:39 I suspect those numbers are kph, not mph as labeled
That would make much more sense, I can definitely check for that. In any case, it seems for some reason the previously faulty TCU activated the lockout more like the na - at least for 4th gear I am sure it did it. Partnumber is the same as the replacement... strange.
Maybe installing an n/a TCU would be a fuel economy hack? :D (goodbye clutch)
misha wrote: 15 Nov 2022, 15:17 Doesn't matter as long as it's correct for your car.
Misha, thanks for that note on the date code. I was looking in parts the other day and had a 1998 and a 1999 TCU and was wondering how to tell them apart, now I know!
Has thanked: 1843 times
Been thanked: 1710 times
The lock up is around around 90 kph? Not sure what those numbers are?? Now I recall testing for this with a Volvo shop foreman years ago, but now can't recall if it was a 4-speed or my R with the 5 speed auto. It was done in the city so almost all the streets are under 80kph speed limits.
More research required by me!
hausmeister
I was just wondering, because my previous bad tcu did engage lockup around 80-100kmh. Probably also a malfunction if it is not supposed to do it on 2.3turbo cars.
Edit: Fuel consumption is down again after ecu reset. I should not be lazy and swap ecu without removing batter power.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
This table is interesting. My 2000 V70 NA with bad transmission fluid had a weird power drop out at 44 mph. When I asked the forum, they suspected the torque converter have a lock/unlock problem. My problem at 44 mph matches the 3rd gear "lock up off" speed. However, my 2000 V70 is a 5-speed auto. Still interesting and I'd like to learn more about this system.
FireFox31
