Vacuum leak? Topic is solved
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Vacuum leak?
Post by matthew1 »
  • Turbo rebuild
  • New wastegate
  • New throttle body
Problem surfaced after those items. All work done simultaneously. This is not my Volvo... it's my neighbor's S70 T5M. All help appreciated!
Also -> Amazon link
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
If we're talking about the unstable idle, then maybe idle air control ?
1999 V70 GLT
Has thanked: 1853 times
Been thanked: 1714 times
What year is it? Looks like a 99- car with a ETM. If that is the case it does not have an IAC. Going on the power steering pump is also a 99- unit.
I don't have time to look at the video just now, but will look later.
Sounds like either a manifold leak or a air/vacuum leak somewhere, but a large one. Does the car have a standard muffler system on it? It just does not sound like one.
matthew1
Site Admin
Post by matthew1 »
Oops yea 1999. Thanks for everyone’s input. I’ll loop in Wes my neighbor and we’ll go from there.
I’ll ask about the exhaust
Also -> Amazon link
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
scot850 wrote: 17 May 2023, 20:03 Sounds like either a manifold leak or a air/vacuum leak somewhere, but a large one. Does the car have a standard muffler system on it? It just does not sound like one.
I was going to say - It doesn't sound like it has exhaust hooked up...or has a major hole somewhere.
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
When we say "new" throttle body, does that indicate it has been tested and proven to be good after install via VIDA? The reason I ask is there is many parts over the last couple of years that haven't always worked the first time around. I think some of this we can blame on supply lines drying up.
Were all the gaskets replaced as well? I'm thinking intake and exhaust have leaks. May be worth it to smoke test both the exhaust and the intake... Should be obvious where the leaks are... I'm sure I'll get flamed for suggesting it, but I really like a torque wrench whenever we have an item with more than two points of fastening.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Sounds more like a gross exhaust leak. Might take a hard look at the expansion bellows inside the flex mesh downstream of the turbo.
matthew1
Site Admin
Post by matthew1 »
I've pointed Wes to this thread. He may answer it himself, and if he doesn't I will update it when I hear something.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
The throttle body was on wrong. It was installed 180° off.
After the fix:
Also -> Amazon link
