2000 V70XC AWD Rear Spring Replacement
m96ag
Year and Model: 2000 V70XC
Post by m96ag »
Hi,
Has anyone replaced the rear springs on a 2000 V70XC AWD? I can't find much information on the procedure besides a dead link to a Sweedspeed forum post.
Thanks!
Has thanked: 2203 times
Been thanked: 1852 times
I tried to find something on this but couldn't. I did replace the springs while replacing the rear sub-frame on my AWD V70R.
You have to remove the rear shock absorber. To do this you need to remove the rear floor from the trunk area. Then there are 2 oval shaped plates, one either side with 2 x 10 or 12mm bolt heads. Remove those and you will see the top of the rear Nivomat struts.
The only way I have been able to remove these are with the Volvo tool. It allows you to hold the center threaded shaft while turning the nut.
You can also do it with a impact driver, but retightening them you have to torque them and that is hard to do without the tool.
With the car off the ground at the rear, you can remove the rear struts. You have to remove the retaining plates which also hole the parking brake cable. That has a 10mm not for the cable. Undoing the other 2 bolts and removing the plate allows the strut to drop out the center of the spring. Now my memory is foggy. I believe you have to undo a couple of bolts to disconnect the outer end of the lower control arm to allow you to remove the spring.
That is all I can remember.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
scot850 wrote: 25 May 2023, 23:17 I tried to find something on this but couldn't. I did replace the springs while replacing the rear sub-frame on my AWD V70R.
That sounds about right. I had the self leveling Nivomats done on my '99 XC and remember them having a bit*h of a time getting the clearance on reinstallation because they wouldn't drop the rear. They did eventually have success...
I'm thinking I had to disconnect the lower control arm to get the springs out. Sorry it has been about 6 years since I did this last.
befarrer
Year and Model: 1998 V70 AWD
Been thanked: 24 times
Post by befarrer »
I did it the other year, I think I removed the trailing arm from where it attaches to the chassis. I just removed the bracket, 3 bolts per side.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
