bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
jsrnsis wrote: 21 Jun 2023, 05:54 I finally got the headliner replaced in my 850 sedan, but of course my sunroof headliner trim shattered into many pieces. There's a lot of posts about people breaking these, but was wondering if anyone had a better solution than attempting to glue it back together? I know RobertDIY says you can use a 960 headliner trim with a little trimming, but was looking for something more readily available before I went to the junkyard with a tape measure. So far I know the sunroof lining from a 2007 Ford explorer is too small.
I used some of this stuff and painted it with Duplicolor interior fabric/vinyl paint. https://www.amazon.com/SYOAUTO-Guards-U ... dGY&psc=1
This is by far my favorite solution to this problem.
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
bmdubya1198 wrote: 21 Jun 2023, 13:49
This is also what I have done on our cars.
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 328 times
Been thanked: 87 times
Post by CIK7 »
A couple months ago I removed the headliner and managed to take out the sunroof trim piece without breaking. I could feel that it might have wanted to break. But ill try to be gentle when reinstalling it.
To everyone: keep an eye out; Ill be posting after-pics of the end result.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
bmdubya1198
CIK7 wrote: 21 Jun 2023, 19:12
Wow, that’s impressive. You may be the only one to ever remove that trim in one piece!
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
I was looking at things like that but couldn't tell if it was big enough to fit over the headliner, backing, and sheet metal around the sunroof. I didn't know if it would be able to form into the corners of the sunroof either.
It's very nice driving around with the windows down without having orange foam flying around and the headliner flapping in the wind. Which is nice because my AC only works at full fan speed and likes to conk out at low speed.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
bmdubya1198
jsrnsis wrote: 22 Jun 2023, 06:35 I was looking at things like that but couldn't tell if it was big enough to fit over the headliner, backing, and sheet metal around the sunroof. I didn't know if it would be able to form into the corners of the sunroof either.
It will fit. It depends how thick the headliner backing is too, but fortunately this stuff is pretty flexible and has no problem going around the corners and forming to the edge.
Has thanked: 1506 times
Been thanked: 3818 times
Almost made the classic mistake of replacing bottom cylinder head before installing the thermostat housing. Its not completely non-recoverable but its a nasty job putting that on in place.
Cleaned parts, waiting for FCP to deliver the gaskets..
CIK7
Post by CIK7 »
abscate wrote: 22 Jun 2023, 12:44 Almost made the classic mistake of replacing bottom cylinder head before installing the thermostat housing. Its not completely non-recoverable but its a nasty job putting that on in place.
I thought there was only 1 cylinder head??? :D :lol:
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
I'm glad you said something. I'm about to start reassembling my block abd removing that thermostat housing was terrible.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
I have some posts about removing sunroof trim. I think it's possible to make a tool to get under the clips to guide them off the roof metal. See those posts and maybe you can create a tool. Then bring it to a junkyard and try to harvest a sunroof trim. I'll be trying to remove mine at some point...
In other news, I missed out on an 80% nice 1998 front driver's seat at a nearby junkyard. I had the yard send me pictures which revealed that all four doors had been removed, letting both nice front (heated) seats get drenched. Maybe I could get the seat back (which is all I need) and hope it's not moldy. Really, I should check car-part.com for each of the very many variations of front seat once every week or two so I don't miss another one.
FireFox31
