hello evryone.
i have just received a vadis dvd, installed it ok but do not know the user id and password. can anyone advise here please. i have emailed the supplier who has not responded. the supplier is www.autocare4u.co.uk
vadis dvd user id and password needed help!
les & reilly
- Year and Model:
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I bought mine from a different seller so don't know if the user and password would work.
On the offchance that they will I am sending the info by email.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Try this
To start the installation, put the CD (or DVD) with Label ?Setup? in your CD-Rom. If the setup program doesn?t appear after the disk is inserted, or if you have the program on other medium, run the file ?setup.bat? manually.
* When the program starts, select ?Custom? install mode and press Next to continue.
* Keep pressing Next at every new screen until the program reports a successful install. This may take as long as 10-20 minutes depending on your computer speed.
* When a screen indicating a successful install appears, press OK to fininsh the installation.
Starting VADIS for the first time
Click your start menu and locate VADIS. Start the program. A window will appear prompting you to enter a user id and password.
User ID: SYSADM
Password: NQZ5-XC3E-P8HD-A2SU
Password must be written exactly as above, dashes (-) included. After you?ve entered the information above, do not press any keys. Instead, use the mouse to click the button to the right labeled ?System Configuration?.
Here you must create a new user.
User ID: - Enter a name between one and eight characters.
Password: - Enter a password between one and eight characters.
The below options are:
User Language - Language that will be used for the user. What you can select here may vary depending on your install (CD, DVD, etc).
Information Types ? What information the user should be able to access. Press ?Select All? or pick individual components.
Partner Group ? Select Volvo Cars Europe or International Misc.
When the above steps are completed, click ?Create New User? and the username will appear in the top left list. Configuration is now complete, press ?OK? to continue.
User ID: SYSADM
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Good information....I believe the system password you posted and over-all user name are the same but the rest of the procedure should prove very helpful. I have all of this in a file at my home but currently I'm close to 500 miles away from home until Saturday evening. Hey, but at least I'm having fun!
les & reilly
- Year and Model:
thank you to everyone very much for the replies. i have discovered the codes you given me are in with the information on my computer from the dvd.
i owe the firm an appology who i bought it off, as they are genuine. however, they owe me an appology because i waited a long time for my dvd, so i guess were even there.
i am not as good with computers as i am with cars and electricals, if you know what i mean, im by no means an academic who could work in an office, that sort of stuff isnt for me, im more of a practical person so my down side is the computer.
once again, many thank for the responses everyone, its nice to know im not alone when it comes to having problems with my car.
les (& reilly, gs dog)
When i try to install vadis i get a prompt for Client ID #, Security # and 2 others. Everyone says keep pressing next but mine doesnt work like that for some reason i have the user name an pass but not ID or securuty # and the other 2
1998 S70 T5M, Classic Red, 17" Mille Miglia Avia, Kuhmo Escta ASX, IPD intake, IPD upper engine mount, IPD HD poly trans mount, OMP strut brace, (IPD HD TCV & Autometer Boost gauge to be installed)
MadeInJapan
Kurt5, I guess I posted basically the same as above to you over on S.S. and it did not help. I have never heard of those being requested for installation so your best bet is to contact the person you got the disc from. Otherwise, search for VADIS Torrent and you'll most likely find a new download for a different version for which the above information works.
Oh, you'll need to do some research on Torrents and download a torrent client such as Bit Torrent, etc. (there are many different ones out there).
Kurt5,
I dont know if you were ever able to resolve your issue but I think I found out how to fix it. I was having the same problem. When you hit custom install the first prechecked box is for a program called security letter. Unclick that and the problem is gone.
- 1770 Views
Last post by KnucklesBusted
- 2903 Views
Last post by packetfire
