Sway bar/end link noise?
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Re: Sway bar/end link noise?
Post by 5rivers »
Ok, here are some pictures of the inside of drivers side rim:
On the outer tie rod, marking from rubbing against the rim:
On the strut bolt to spindle/knuckle, note the gray colored residue/flakes (between the bolt head/nut and top of spindle):
I did replace the slightly longer bleeder screw with a shorter one, but the top of the longer screw was not damaged and the rubber cover was still on the screw.
The inside of the front passenger side rim shows no scarring at all.
Last summer I had to replace the passenger side caliper. Are there different sizes of calipers between the base model V70 and the turbo?
I believe the replacement caliper was off a non-turbo V70. Not sure if that makes any difference.
Thoughts??
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
Has thanked: 1507 times
Been thanked: 3824 times
That’s awful. That will destroy that alloy wheel if it continues, then you end up on a flatbed like Juliette…even the cat hid….
5rivers
Post by 5rivers »
Gosh, Abscate, are you okay? That tire, rim, suspension, et al looks horrible!
Still wondering what I need to do...change the caliper, the tie rod??
Change the strut assembly??
5rivers
Has thanked: 1853 times
Been thanked: 1714 times
Can you post a picture of the tie rod. Are you sure you do not have them on the wrong sides? The 'bow' of the tie rod should point toward the strut. In the picture is is hard to see but it looks like it points to the back of the car.
scot850 wrote: 19 Jul 2023, 23:30 Can you post a picture of the tie rod. Are you sure you do not have them on the wrong sides? The 'bow' of the tie rod should point toward the strut. In the picture is is hard to see but it looks like it points to the back of the car.
Nailed it!
Scotland for the win!
5rivers
Post by 5rivers »
Indeed, the wrong tie rod was installed (I was sent two passenger sides when I ordered these back in 2021). Makes sense to check the contents of the boxes when they arrive!
Have ordered two new tie rods!
Thanks to all for your help in solving this mystery!! :)
5rivers
