Has thanked: 1850 times
Been thanked: 1712 times
Battery, charging or drain issue? My buddy went through an issue of poor starting and battery charging problems. Concluded his 2 year old Costco battery was bad. Went to remove it to get replacement (4 year 100% warranty!), only to find someone had not tightened the ground clamp fully and it was loose.................!
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I managed to start my T5M with only 10.5V showing at the battery once (yes with the starter). Not quite sure how. Maybe because I said please.
When my battery died it was showing 12.5V, but could only put out about 12 amps.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Has thanked: 1505 times
Been thanked: 3818 times
WhatAmIDoing wrote: 18 Jul 2023, 21:26 I managed to start my T5M with only 10.5V showing at the battery once (yes with the starter). Not quite sure how. Maybe because I said please.
That’s the 1998 saving you. Probably that is telling us the bus sensitivity of the 1999 is inthe ECU to ETB link , which makes sense. My observation above that the ETB wasn’t doing it initialization ( click…whine…8 seconds…click….silence) is consistent with this
P80 spare tire well drain
I managed to leave the trunk kn Evita up during a deluge and had 3 inches of water in the well
Looking for a rubber plug drain but can’t find one , is it buried under sealer ??
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Inside job, outside a tropical swelter -
Before:
After (test fit):
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
That bumper mount wasn't TOO bad...
Are you done with that , foggy?
:lol: :lol: - Lots of life left..............? :roll:
I still have that to look forward to on the 850 I have been helping to get back to good health. It will depend on how the welder views and prices the repairs! Reasonable and then I get to tackle an equally crusty pair of rear bumper mounts.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
foggydogg wrote: 20 Jul 2023, 07:40 Inside job, outside a tropical swelter -
You should have saved that for the "identify that rusty part" thread lol.
Replaced tailgate lock and latch plate oN Shagg, got all the plastic off intact!
No more slamming or light on dash. Parts about $250 from Mother via her Favourite Child Partner
