SOURDOUGHJIM
- Year and Model: 2004 V70 2.4
- Has thanked: 53 times
- Been thanked: 27 times
A bit cooler this morning so I gave the V70 a wash and wax.
- 20230723_191026.jpg (486.83 KiB) Viewed 596 times
- Has thanked: 304 times
- Been thanked: 517 times
Looks good! I need to wash all of my cars... they're filthy.
- Has thanked: 1850 times
- Been thanked: 1710 times
As to the V70 XC's being a good source of NLA parts. I used to pull a bunch of parts, but things like the fuel pumps are likely bad. Not sure you can really test them before pulling unless you can get a jump pack snuck in to try to see if it runs. before pulling it. Need to figure out the connections in the trunk and which wires to use, but a lot easier than 3-4 hours pulling the stuff out to find it is bad.
The question is how badly rusted do the cars get in your area. If the answer is East coast rusty, maybe little from underneath is worth pulling.
We could maybe look at starting a thread we can add to for NLA parts for AWD P80's, and or rare/expensive parts that may be worth harvesting?
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 68 times
There was a thread on volvospeed I had seen a while back with excellent info on parts numbers for practically all the unique parts on the rear subframe of p80 awds. It even had equivalent parts, since Volvo used a lot of rwd parts but used a different part number for the AWD model.
Volvospeed was dead for a while, I haven't been able to find that thread. All that info there one day and gone the next.
As.to what I did to MY volvos today, I got this turd back together and running under its own power to find out it drives like a dream. And I got this truck all loaded up for a rescue of my new piece of Swedish dead weight.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
- Has thanked: 292 times
- Been thanked: 765 times
Changed the radiator and the lift gate struts on the 96 850. Old rad was a transplant from a previous 850 and finally a seam gave out at 250k. Also replaced lower radiator hose, the Napa hose on there was about 100k it was there when I got the car in 2013.
The mounting holes in the Nissens radiator did NOT line up correctly with the holes in the factory AC condenser. I had to put the condenser a little crooked and use only 3 of 4 screws. For the fourth hole that lined up with neither of the holes in the radiator on the bottom corner, passenger side, I used two zip ties. Gosh how do they make the radiator so inexpensive ($120, I went with FCP)? … build quality seemed mediocre overall, I’m expecting to get about 5 low-mileage years out of the new radiator before it cracks somewhere.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
That's disappointing, the Nissens I installed 3-4 years ago fit perfectly. Quality control continues to roll downhill at a very fast pace.
The amount of parts I have to send back (especially to FCP, believe it or not) for customer's cars is astonishing. For example, a BMW wheel bearing that was the COMPLETELY wrong size. Now I have a car on my lift holding up work for a few days until I get a new one... yay!
Like wise. When I fitted a new Nissens about 5 years ago, it fitted perfectly. Unfortunately, maybe product has been outsourced for manufacture to keep costs down.
jsrnsis
The nissens radiator I bought in 2021 fit perfectly fine. It was for a 94 non-turbo, automatic transmission.erikv11 wrote: ↑24 Jul 2023, 07:28
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
Can you spot the leak in the aging Blackstone radiator I replaced?
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Can't say I have ever seen one fail there before. Most I have seen fail have been at the seems but also around the top hose.
