Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 41 times
Been thanked: 28 times
Post by Cees Klumper »
Serviced the 2001 C70 T5: engine oil + filter, cabin air filter, fuel filter and replaced the brake fluid. A year ago did the timing and serpentine belts, all pulleys, waterpump. Runs very sweet.
Has thanked: 1505 times
Been thanked: 3818 times
Did that develop three independent cracks mid -plastic?
Crazy
Has thanked: 292 times
Been thanked: 765 times
Appears so to me. Maybe the plastic was just thinner on that area?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Found this little guy hanging out under the turbo while searching for a coolant leak. Pretty sure it's an exhaust stud. But I don't have any exhaust leaks and can't find an empty hole.
And today while rotating tires I've learned my brake hose are beging to collapse internally. Oh what a fun weekend I have ahead of me.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Has thanked: 1850 times
Been thanked: 1710 times
Heatshield bolt, or downpipe flange? Or is that the one you lost last time you were working on it.............? :shock:
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Having just removed all the exhaust bolts, that is most certainly an exhaust stud. There may be enough tension across the exhaust manifold to prevent a leak. You would need to move the exhaust shield to see. Could also send a bore scope camera to visualize the studs.
xyna
Year and Model: Volvo 740 1990
Post by xyna »
Did an oil change on my V70 today. Now slightly regretting that I bought a V70 with the infamous Magneti Marelli ETM, does anybody have experiences of replacing the throttle position sensor within the unit?
WhatAmIDoing
ZionXIX wrote: 26 Jul 2023, 20:58 Having just removed all the exhaust bolts, that is most certainly an exhaust stud. There may be enough tension across the exhaust manifold to prevent a leak. You would need to move the exhaust shield to see. Could also send a bore scope camera to visualize the studs.
scot850 wrote: 26 Jul 2023, 15:02 Heatshield bolt, or downpipe flange? Or is that the one you lost last time you were working on it.............? :shock:
I figured it was an exhaust stud. I'll send my cheap borescope in to investigate. Definitely wasn't one I lost. Which means it's been bouncing around down there for potentially over 5k miles.
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Fixed my code scanner today. Old sd card was slowly dying and had corrupted a file that directs the user to the locations of files. flashed a new card and the scanner works again.
2008 S60 2.5T Auto (Sold)
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
Worked on cleaning up some Rust... :?
Pulled out the whole line of glue and after some rust converter will slap on some paint. Probably not going to look too pretty, but at least will not rust any more. Taking out the window is too much to ask for now, also the rust does seem to only be below it.
850 T5-R '95 auto Image
