Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
ZionXIX wrote: 04 Aug 2023, 15:26
volvolugnut wrote: 04 Aug 2023, 13:53 Previous experience in 1970's for three summers. It paid for my college.
That sounds nice. Definitely couldnt pay for my schooling with a Sumner job.
My pay was cheap, but my state university in 1970's was also cheap. It seems like the pay was about $6 per hour with some overtime. Tuition was around $30 per semester hour and monthly dorm with meals was about $150. A lifetime of engineering salary - priceless!
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Prepping yesterday for today's job of giving the V70 a brake fluid change, I have no paperwork of it ever being done before and if it really is 18 years old it's long overdue. Today's job was to try and loosen the bleed screws which I really wasn't looking forward to. The plan was to soak all the nipples with PlusGas overnight in the hope they would come out without breaking. However I was a tad impatient and with both rear wheels removed and the bleed screws soaked them in Plus Gas I decided to start by lightly tapping the surrounding area with a small hammer, first one side, then the other, more PlusGas and more tapping and repeat. I then dug out my vintage Snap-On RXSM-11 flare nut spanner which I've had for over 45 years and applied some pressure to the bleed nipple. to my surprise they cracked open and I allowed a small amount of fluid seep out. The front was done with the same procedure and all 4 are ready for today if I manage to source the correct but rather scarce DOT4+ fluid.
While I had wheels off I decided to test fit the recently refurbished Mimas winter wheels to make sure they were not rubbing, glad I did this before winter as I had to remove the excess the powder coating from the centre bore which is a total ballache to do.
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
P80GLT wrote: 04 Aug 2023, 23:48 Prepping yesterday for today's job of giving the V70 a brake fluid change, I have no paperwork of it ever being done before and if it really is 18 years old it's long overdue.
Brake feel was significantly improved on my 08 S60 with a brake fluid change (mine was unknown age too), need to do that on my C70. I used an air compressor powered brake bleeder and definitely helped speed the job.
08 C702.5T (sold)
The non-Swedes:
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
Im working on replacing the radiator right now as it has a leak. I was taking the plastic splash guard thing out from under the radiator and... You'll never guess what fell out when I took it off. A 10mm socket!
2002 v70 X/C 288k miles
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
02V70 wrote: 05 Aug 2023, 14:52 Im working on replacing the radiator right now as it has a leak. I was taking the plastic splash guard thing out from under the radiator and... You'll never guess what fell out when I took it off. A 10mm socket!
I was driving with a 13 mm socket on a rear engine pad bolt for like 4 or 5 years.
02V70
Post by 02V70 »
I finally got the new radiator in as well as some new coolant hoses. This video really helped:
P80GLT
Post by P80GLT »
Krons wrote: 05 Aug 2023, 06:45 Brake feel was significantly improved on my 08 S60 with a brake fluid change (mine was unknown age too), need to do that on my C70. I used an air compressor powered brake bleeder and definitely helped speed the job.
No difference in by brakes now that the fluid has been changed but it will make braking safer without the moisture content of the past 18 years
This is what 18 year old brake fluid looks like?
2010 XC90 SE...SOLD
2005 V70 2.5T SE
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Yay....
Blacklab467
Year and Model: 2007 xc 70
Been thanked: 264 times
Post by Blacklab467 »
I finally found an effective method of deep cleaning the leather seats. A friend of mine is a professional detailer and recommended a product that actually gets all the grime out of the grains of the leather, I used Chemical Guys Leather Cleaner and a drill brush (soft bristle). The cleaner cost $16 for 500ml, the whole seats front and back used about 1/3 of the bottle and the job took under an hour. I should have taken before AND after pictures but I can assure you that the seats were filthy before as I have 2 Labrador retrievers that are almost always with me in the car, going swimming and trudging around the muck at the dog park. I would highly recommend this product, however I really think the drill brush is also necessary to get the leather looking like new.
2003 XC 70 (sold)
Has thanked: 1853 times
Been thanked: 1714 times
Those look really good for 20 year old seats! Good to know now as I could do with tackling the Toyota light beige seats.
P80GLT, I also have a Snap-on flare wrench. One of the best purchases I have made tool wise!
That brake fluid needed changed but seen worse!
