BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Haha, no.... “Alfa brakes,” VOLVO subframe.”
Has thanked: 1853 times
Been thanked: 1714 times
I prefer the manned (personned??) checkouts, so I must be one of the 'older people' you mentioned. :shock: :lol: :lol:
I can't be bothered to look up codes for different vegetables, fruit and bulk stuff. It also means I have to get my glasses out to read the screens, but I can see well enough for the cash/card payments.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
scot850 wrote: 12 Aug 2023, 18:19 I prefer the manned (personned??) checkouts, so I must be one of the 'older people' you mentioned. :shock: :lol: :lol:
:lol: They can certainly be easier, and that's why I like to see them remain an option. I don't do any of the major grocery shopping in my house, so when I'm at the grocery store I'm not usually buying more than a few things. In which case, the self checkout is quick and easy.
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
I repaired the wiring.
I have a cable i don't know what it is for. It comes from the square on the top of the ACC.
I have a second cable that seems to be plug to this first one (grey). I think they might be plugged together, no ?
I've replaced the hose on the top of the fuel tank the one that drives gaz upper the feed hole.
I've unbolted my rear wiper, its motor is dead. A used part normal this week.
I'm gaining more and more confidence in my maintenance work. And thanks to you guys!
bmdubya1198
Yeah, that appears to be the clutch wire for the AC compressor.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
Greased the edges of the rear brake pads to try to stop the squealing (seems to have helped a little bit -- time will tell), changed the engine oil and filter 10W-40 Mobil 1 and Mann, cleaned and reseated the connector on the MAP/Baro sensor (pn 1275342) after getting the P0108 engine code again -- had this once about 10 years ago... code hasn't come back yet.
Cleaning, cleaning, cleaning. Takes longer to clean stuff I pull from the junkyard than it takes to pull them in the first place. Vacuum bagging amplifiers units and cables, as well as another 2000 NA ETM after cleaning.
Also repairing an LH lower dash panel and under dash tray. Modifying the stupid flimsy screw retainer for the undertray with a strip of thin steel and a metal spring 'U'-clip for threading the retaining screw into which should be a lot stronger than the original plastic threaded piece that breaks off.
Finally tagging locations of parts on stock list and cleaning the remaining amp cables (removing the sticky residue from the foam covering). All that is left for the current hoard pulled is to clean the SC-901 unit including the laser for the CD player and then testing the small speakers, amp, cables and SC-901. Then I just have to clean some wooden dash pieces for a friend and organise to start packing for shipping!
Has thanked: 1507 times
Been thanked: 3824 times
Still trying to sort out the undocumented two part numbers for the 1998 99 00 purge valves
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Couple of pics (not mine) from the Dumfries show
I was captured giving the car a quick wipe over when I arrived. I left Glasgow and by the time I reached Kilmarnock the heavens had opened. When I arrived at Dumfries it was dry, even the grass was dry and we never saw any rain all day. Result...
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
850 LPT
Year and Model: 96' 850
Has thanked: 332 times
Been thanked: 243 times
Post by 850 LPT »
Nice, parked right next to a MK3 Capri :D
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
