ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Thanks Abscate. I think I'm gonna try some local black permatex and just dab a little around the edge before placing the cam cover. For now I'm putting it on hold since I found one of tye camshaft sensor wheels broke.
Also I lost one of the idler bolts and had to come up with an alternate plan. I'm not proud of what I did.
Has thanked: 1506 times
Been thanked: 3822 times
Easily replaced when you find it.
You can test the depth of the block hole to see if that longer bolt won’t bottom out , too
Dr Dremel can also resize bolts for you. Put a nut on it first to chase the thread , post cut
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
abscate wrote: 31 Aug 2023, 00:32 Easily replaced when you find it.
Hi,
Good idea with the nut. A little taper at the very end helps too to get the bolt started when screwing it in.
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 329 times
Been thanked: 87 times
Post by CIK7 »
I broke the sunroof today. One of the arms that guide and heighten the sunroof as it raises to vent is broken. I managed to get it closed with some persuasion. Now I cant open it until Im ready to take a crack at it.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1853 times
Been thanked: 1714 times
Take the whole head liner out and the sunroof 'cassette'. You will be glad you did as it is a challenge to get access to some of it and some you can't disassemble without removing it all.
volvolugnut wrote: 22 Aug 2023, 17:44 OK, the Zip tie spring compressor photo was fun, but PLEASE DO NOT USE ZIP TIES TO COMPRESS DANGEROUS SPRINGS!
You can get hurt or killed!
MVS legal has forced us to post a reminder that proper tools should be used…and safety footwear at all times
I was watching a TV program about 2 brothers who get commissioned by one of the auto channel program channels to build unusual vehicle based on something they pull out of a barn or such. I was very disappointed to see the guys lift a pickup by the center of the rear diff, no wheel chocks, and no axle stands and start crawling under it! Wow, what a way to teach the newbies to car repair!!
RobsS40
Year and Model: 2006 S40 T5 AWD
Has thanked: 2 times
Been thanked: 7 times
Post by RobsS40 »
You mean, don't do like these people?
https://www.swapmeetdave.com/Humor/Work ... ppedUp.htm
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Hay-SOOS!
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
I finally finished 2 rust repairs (tailgate and roof-antenna hole).
So I'm driving it again and again got a srs code <212 driver airb. Open c.> after it sat for a while. Meh, I ordered a used clock spring, maybe I'll try that as a fix when I feel like it. It seems to go away after I clear it until it sits again for a longer time.
Otherwise it is running fine :)
850 T5-R '95 auto Image
