Hello guys!
I did engine swap on my 850 this year (2.0 turbo) but I never got it running again. Fuel injectors does not work. Fuel rail is clean and it has spark. It starts sometimes on starting fluid but only for few seconds. Injector relay is not very happy but it works fuel pump too. Could it be crank sensor when it has spark?
Thanks for your help!
No fuel from injectors
Vladimir24
- Year and Model: 1995 850 t5
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
First thing as you i personally would use multimeter at the start to measure so that you can find +12V from the injectors (injector plugs) constantly when ignition is on. ECM does pulse Ground so use any like engine block as ground point measurement and not the plug itself.
- Has thanked: 305 times
- Been thanked: 517 times
Noid lights are also good for testing for injector pulse (essentially a light bulb that plugs into the injector connector). I would also check the actual fuel pressure at the rail.
If there is no injector pulse, check for any error codes at the diagnostic connector. It could be an issue with crank or cam signal. If there is low/no fuel pressure, your problem is more likely to be with the fuel pump or relay.
Vladimir24
It does not have spark anymore
- 291 Views
Last post by pinegrovedave
- 1496 Views
Last post by 93Regina
