P80 triple fan relay 9442933 NLA
- Has thanked: 1506 times
- Been thanked: 3822 times
Not a big deal as the relays are reliable and there are tons in junkyards but no longer available new or aftermarket as of Sep 23
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
hi abscate i have recently purchased several relays for the 850 from ali express and so far all 3 have worked just fine and as the dealer has none at all i took a chance,i think maybe they do more for more modern volvos than mine! post is def faster than some as well.
i did not find the fuel pump relay any where in uk new,the ali one is made in eastern europe not china but hungary looks exact same except grey in colour,good luck
- misha
- Has thanked: 152 times
- Been thanked: 402 times
It works for now.
If i were you...i would junk that in the bin and buy at least a used Volvo one....before you loose cooling fan(when needed) and overheat the engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Fuel pump relays are red,green and yellow and have number 103 on top of them.
You will need the one with EXACTLY the same numbers like the old one.
That grey one which says made in Hungary is main fuel injection relay and it's located on cooling fan carrier.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1853 times
- Been thanked: 1714 times
Sheesh! More parts to add into the stash on the next junkyard run! Oh, forgot, already have a few in there!!
- 11 Replies
- 1369 Views
Last post by polskamafia mjl
- 1529 Views
