ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
abscate wrote: 17 Sep 2023, 04:53 Excellent! It’s best to give them 20-30 minutes at idle to let the lifters pump up, if you drive it, keep it under 3000 rpm. Click click click. If valve timing isn’t sorted out yet, you can get a pop or two from the exhaust
I see. So the VVT can be a bit touchy after sitting for 6 months? If a cam seal suddenly blew out, would that make an audible noise?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
ZionXIX wrote: 17 Sep 2023, 06:43
I guess if there was some extreme crankcase pressure. But you'd probably see a puddle of oil if that happened.
ZionXIX
Post by ZionXIX »
Ok I figured out the mystery *pop* from the maiden voyage. The intake from the turbo blew off at the throttle body. This morning I drove the xc90 on a Sunday morning donut run and she was running loud with sluggish power. I thought I was hearing an exhaust leak.
I can't believe it drove as well as it did. After I got home she would just stall at every startup.
Also gave the MAF its first cleaning in 18 years. Now I'm currently installing one of the retrofit android tablets.
bmdubya1198
Yep, that'll do it! I've had that happen, it will kill power pretty quick. I'm surprised it took that long to want to stall.
Has thanked: 1502 times
Been thanked: 3813 times
Elizabeth test drive , lumpy and crappy. Found loose ground on 1/2 coil pack
Those turbo induction clamps Volvo uses are , special, with a spring band in the middle. Designed for purpose, I bet.
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
abscate wrote: 18 Sep 2023, 10:16 Elizabeth test drive , lumpy and crappy. Found loose ground on 1/2 coil pack
Well, you know, if you cut them in half they don't work too well :lol:
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 1841 times
Been thanked: 1710 times
With the pending 98 V70 suspension refresh on the near horizon, I have to get my main workbench cleared to work on the parts.
First was tackling the pair of rusty but good front P80 brake calipers and big brake caliper brackets they were mounted to.
What amazed me was the condition of the aftermarket (awful) slider pins. How/if these brakes worked amazed me!!
Really dirty slider caliper pin
Even after cleaning it is not worth keeping due to the surface damage. This will in turn damage the slider boots.
Cleaned slider pin
Cleaned slider pin
I still have a bunch of used OE pins that are in way better condition than these. The other issue I did not show is the damage to the 7mm hex heads. I have received these on reman'd calipers that were so bad I was unable to undo then from new without then rounding!
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Took a scope to my two spare engines for the 98 v70. Both engines clearly show all the cross hatching however there are some singular scratches on the wall. None of the scratches look that deep on the scope however it does show a bit of wear. I am thinking that both perspective engines would need a valve stem seal job.
If the cross hatching is clear across all walls of the cylinder then would a handful of sidewall marks be something to be worried about?
2008 S60 2.5T Auto (Sold)
The bottom end of these engines are extremely tough. I remember one ad said Volvo used high carbon steel in the block, the only other maker doing this was Rolls Royce , it claimed.
I would assume the bottom end is fine with 99.3% certainty
bmdubya1198
Block/cylinder failures on these are extremely rare. The only time I've passed on reusing block was when it had sat with water in the cylinders from a serious head gasket failure, and had insane rust buildup on the liners.
