1998 V70
- Has thanked: 1507 times
- Been thanked: 3825 times
Much easier than adding a turbo to an NA motor!
You will need a tune or an ECU a that supports a turbo motor , of course
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
I believe that the wiring harness under the hood is different from turbo to NA. That is probably the reason most don't attempt it.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1855 times
- Been thanked: 1714 times
Wiring harnesses are different. If you are determined to try it, at least you are using a manual car. I had a friend looking at trying this on a 2000 S70 NA to turbo but that is just mind blowing to do.
Having said that. There was a guy here in Alberta selling a 850 NA manual with a 850R motor in it. I never asked him if it ran though!
https://www.kijiji.ca/v-cars-trucks/red ... 1671292823
It would suggest it runs...............
- 1919 Views
Last post by MrAl
- 9 Replies
- 1793 Views
Last post by bmdubya1198
