P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
yanga001 wrote: 06 Nov 2023, 06:59 Will do a flush later and post up the contraption i use to flush out the system fully. Might make steering a little lighter.
Remember there is a fixed filter in the reservoir that should be cleaned out when changing the PS fluid
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 263 times
Post by Blacklab467 »
There was a good writeup on a good method of flushing the PS fluid, basically engine off with front wheels off the ground and going left to right with the steering wheel slowly with the return line going into a catch bucket and keep the reservoir full. I did it twice on my car and the fluid is crystal clear. Check your fluid requirements, I believe you require Pentosin 202.
2003 XC 70 (sold)
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Blacklab467 wrote: 06 Nov 2023, 07:48 There was a good writeup on a good method of flushing the PS fluid, basically engine off with front wheels off the ground and going left to right with the steering wheel slowly with the return line going into a catch bucket and keep the reservoir full. I did it twice on my car and the fluid is crystal clear. Check your fluid requirements, I believe you require Pentosin 202.
I did the same with my partners RDX but found that removing the serpentine belt and putting an electric rachet on the pump nut can force all the old fluid out. We ran it on a low speed while turning the wheel and got the fluid completely clear. Her steering went from tough and noisy on the new pump to smoother than my car :P.
Napa canada has some pentosin at a half decent price. I'll flush the screen when i take out the reservoir. I have a vac based pump which does wonders for that.
2008 S60 2.5T Auto (Sold)
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
These two should help those interested in a power steering flush per wheel off the ground. Includes cleaning the reservoir.
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
It's all back together now and I drove my V70 to work today for the first time since my daughters accident. It looks a little funny with the mismatched front bumper, but it will get painted hopefully soon. Feels good driving that car again, plus it releases our 240 from daily duty :D . Good timing of everything because that car will be back in the garage for the winter soon.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 1506 times
Been thanked: 3822 times
Good. Now we can fix Mathilda
Harvested ac compressor, alternator, PS pump from Shagg
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
I accepted the fact that I need to change the alternator in my S60. Groaning like a pig and still occasionally get battery light on dash.
04s60 2.4
04xc70 2.5t
yanga001
Post by yanga001 »
Touched up the rustproofing job done earlier in the month, ensured i had full coverage. The previous stuff stuck on well and distributed/crept into different areas.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
The 2nd fuel tank door hinge repair failed in a month. Is anyone out there who has used rivets to fasten hinge to the body?
MoVolvos
Post by MoVolvos »
xHeart wrote: 13 Nov 2023, 07:56 The 2nd fuel tank door hinge repair failed in a month. Is anyone out there who has used rivets to fasten hinge to the body?
I used fasteners. If your door pops open leave it alone unlike the zip tie and shrink wrap I tried to improve it with. Everything still working fine however.
(EDIT) Keep in mind this will no longer be a break away which Volvo intended the door hinge to function. Will have both door and body damage if caught on something.
viewtopic.php?p=611306#p611306
