Hi,
I've been reading about this of late also. It's spec'd for GM cars from what i have read.
I have also read now that Prestone says it is ok to mix with DexCool in a GM vehicle but not sure about a Volvo.
There seems to be varied opinions on the web with some things.
Yesterday I was looking up the density of copper (99.9 percent pure or close to that). I wanted to verify the thickness of the so-called 1 ounce copper clad circuit boards copper layer.
I found right away a value of 8.94 kg/m^3 which is close to 9 kilograms per cubic meter.
Now you have to realize that 8.94kg is close to 19 pounds, and i could easily pick up a 19 pound weight as most people can. Now imagine trying to pick up a hunk of copper metal that measures one meter (about 39 inches) on each side. That's a hunk of metal that is larger than a foot rest for a comfort chair. Could you pick it up? Sure, if it really weighed 19 pounds. Problem is, it's much heavier than that. The real density is closer to 8940 kg/m^3 which would make it a LOT heavier than 19 pounds. No single person could pick that much weight up especially in that bulk form.
So there you have it, a seemingly good reference to the density but off by a factor of 1000. That's the web for ya. Caution is the word.
Imagine if you used that information to design a machine that would hand a one cubic meter block of copper to a human for loading onto a truck. The first use would kill the guy or smash his fingers at the least.
Dexcool coolant ?
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Re: Dexcool coolant ?
- Has thanked: 1507 times
- Been thanked: 3825 times
That’s just a units mistake, a la NASA and the Gimli Glider....
Unless you are fooling with Osmium or Iridium metals are about 10g/cc, liquids 1g/cc, gases 1/200th of that GOT.
Good engineers SWAG everything so that they catch crap like this
Dad anecdote ....1970s. Computers were just coming into the rage in his field , aerodynamic structural dynamics, the study of flutter and vibration or why planes, rockets , and things fall apart.
In come the new fresh faced computer guys from MIT, who tell the old guy they have calculated the flutter eigenvalues on the new Space shuttle wing design
Dad...” give me a minute......thinks......ok
NooB: 13 , 57, 157
Dad: 13, 157 are good...go back and find your mistake in the program that gave you 57
NooB: Gulp....
NooB: 13 , 57, 157
NooB: Gulp....
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 264 times
To be sure you cannot go wrong with the Volvo branded blue stuff. There isn’t very many parts at O’Reillys or Pep Boys that should find themselves on a Volvo.
2003 XC 70 (sold)
- MoVolvos
- Has thanked: 312 times
- Been thanked: 524 times
.Blacklab467 wrote: ↑11 Nov 2023, 06:16 To be sure you cannot go wrong with the Volvo branded blue stuff. There isn’t very many parts at O’Reillys or Pep Boys that should find themselves on a Volvo.
Both Kragon & Pepboys were okay back in the day
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
All it says in the manual is use genuine volvo coolant. Which of these should I buy please?
https://www.oreillyauto.com/shop/b/oil- ... antifreeze
I always just bought the O'Reilly 50/50 universal.
- Has thanked: 929 times
- Been thanked: 1004 times
The G05 works fine and is readily available at reasonable price.
Your choice - premixed or concentrated.
mar601
I'm sort of freaking out about this and want to get the car in to get this dexcool out. I have a tendency to over-react so maybe I can get some peace of mind by asking -----
I had the O'Reilly universal in there (always used that) and I just put maybe a half gallon of the Dexcool in. Going to call the shop tomorrow for an appt. Hopefully, it's not a case of "immediate" damage? I'm reading where rather in time it can clog up the system? I should be ok for a few days you think?
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
I think in the short term, you're fine.mar601 wrote: ↑11 Nov 2023, 10:38 I'm sort of freaking out about this and want to get the car in to get this dexcool out. I have a tendency to over-react so maybe I can get some peace of mind by asking -----
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
As said, don't worry. Just drain and flush, then fill with any GO5 rated coolant. Zerex is one you can get at O'Reillys, AutoZone, etc..
I believe it's a gold colored jug and fluid.
1999 V70 GLT
1999 V70 GLT
- Blacklab467
mar601 wrote: ↑11 Nov 2023, 08:58 All it says in the manual is use genuine volvo coolant. Which of these should I buy please?
So many choices....... and none of them are Volvo branded.
2003 XC 70 (sold)
